Results 1 to 8 of 8
01-02-2009, 11:17 PM #1
ethyleneglicol-propyleneglycol concentration detectors
I would be grateful if someone could provide with some references for manufacturers of ethyleneglycol and propylenglycol concentration detectors %.
It's for a project of industrial cooling in a fruit juice industry
Thank you so much
dvidlleida
02-02-2009, 07:53 AM #2
Re: ethyleneglicol-propyleneglycol concentration detectors
if its a refractometer your after try snap on tools or Kayne May
02-02-2009, 07:57 AM #3
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
02-02-2009, 04:31 PM #4
Thank you all,
but in fact, I'm not interested in a tool that I have to check myself the concentration of secondary system.
I'm lookin for an analyser that installed in the system gives me an Input to my PLC controller in order to have an alarm message.
I know there is a provider that actually I can't remember but I would like to have more options.
I'll give the link when I have it
02-02-2009, 07:48 PM #5
B"H
The instrument which will give a signal to PLC called Inline Refractometer and manufacture by:
Misco, Schmidt+Haensch, Maselli, Cole -Parmer. They are not cheep.
02-02-2009, 08:51 PM #6
A conductivity sensor could be an option.
04-02-2009, 06:58 PM #7
Hi, davidlleida
IMHO ... try to be environment friendly and try to use Temper ... see this
http://www.temper.se/
... without any need to measure concentration all the time ... check this...
http://www.temper.se/Temper_(eng)_Temper_Product_information_Temper_advantages_DXNI-2011_.aspx
quoted
"Product durability
In a sealed container or in a closed system the properties of Temper remain stable, and its durability is unlimited.
Safety
Temper is neither inflammable nor explosive. Temper is less hazardous to health than traditional cooling mediums and does not degrade compared to glycols. It can quite simply be diluted (50% water) and poured down the drainage. Always consult the local sewage work before pouring out large volumes. Temper does not require any special handling or storage measures. The product is suitable to use as a heat transfer medium according to The Swedish National Food Administration"
Best regards, Josip
13-02-2009, 05:34 PM #8
Thank you so much Josip!!
I will contact them.
Oil Concentration Sensor
By Erik Detroit in forum New TechnologiesReplies: 2Last Post: 01-11-2005, 03:33 AM
