Thread: Beko fridge freezer problem
31-01-2009, 05:36 PM #1
i OWN A BEKO AP930 FRIDGE FREEZER. HAD IT FOR 1 YEAR WITHOUT ANY ISSUES UNTIL NOW. THE BOTTON DRAWERS ARE FREEZING FOOD SOLID + THE WATER FILTER HAS FROOZEN SOLID. I HAVE ADJUSTED THE TEMP FROM 4 TO 8 DEGREES BUT EVERYTHING IS STILL ICED UP. ANY HELP APPRECIATED.
NOTE: THERE ALSO SEEMS TO BE AN ODD SMELL COMING FROM THE BACK OF THE UNIT.
31-01-2009, 09:44 PM #2
Re: Beko fridge freezer problem
1st fault it a beko
2nd smell from rear could be gas leak from compressor (need engineer)
24-02-2009, 01:23 PM #3
This is a problem of deforst not happening. CHeck for the defrost controller assembly . Also check for Thermostat which is controlling the Ref Temp.
Hotpoint FF200E Fridge Freezer Fault
By fredalfred in forum DomesticReplies: 107Last Post: 29-12-2012, 01:26 PM -
whirlpool fridge freezer problem
By anubis68 in forum Trouble ShootingReplies: 0Last Post: 04-06-2008, 09:38 AM -
coolinf fan problem samsung rs21 dgrs fridge freezer
By bogtrotter in forum Trouble ShootingReplies: 6Last Post: 21-03-2008, 08:45 PM -
Beko Fridge Freezer Bubbles & Does Not Get Cold!!!!
By scoobey in forum DomesticReplies: 11Last Post: 16-03-2008, 07:12 PM
