30-01-2009, 10:24 PM #1
Can i connect the calculator to TIC(Temp.Indicator Controller)
I want to calculate the efficiency of Cooling Tower so i think, if i connect the calculator to temp. controller (TIC) of cooling tower by which calculator will take the input of temp. value from TIC & then it calculate the applied formula of efficiency.
Nadeem
nadeem_me26@rediffmail.com
01-02-2009, 05:33 PM #2
Re: Can i connect the calculator to TIC(Temp.Indicator Controller)
can you post an example using real data so we can understand what you are trying to achieve?
Can I connect a relay to Freezer Warning Light Contacts
By Contax in forum DomesticReplies: 1Last Post: 04-05-2008, 11:28 AM -
Oil Reservoir connect to low side??
By hendry in forum Technical DiscussionsReplies: 4Last Post: 07-04-2008, 09:52 AM -
SR2 50 models electric SBY diagonostics made simple
By absolute-zero in forum TransportReplies: 5Last Post: 04-01-2008, 05:11 PM
