    2aces's Avatar
    2aces Guest
    Close Control Definition
    Hi There,
    I am just wondering if anyone can help me. I am struggling to understand what is meant by the term "close control". I read that it is to keep a room at a specific temp but is this not what auto does on a daikin / mitsi system? Can anyone explain the difference?
    Jun 2005
    California
    394
    Re: Close Control Definition
    On auto the fan cycles with the temperature. On close, the fan is on all the time while the cooling/heating cycles on temperature. The stratigy being that if the fan is on all the time you get a better temperature mix in the room, therefor closer control.
    11,025
    Also, the thermostats used in close control will have a narrower differential and depending on the system will have better proportional control.
    Electric heater elements will normally be used, in stages sometimes, instead of heat pumps because of the time lags etc.
    Oct 2001
    Nottingham UK
    5,668
    And chilled water with a 3 port diverting valve for the cooling.
    Much better 'close control' than DX but less so with dehumidification.
  1. Denco Close Control Units
    By Freecool in forum Air Conditioning
    Last Post: 05-05-2010, 12:50 PM
  2. wall mounted close control
    By dannycool in forum Air Conditioning
    Last Post: 25-01-2009, 07:36 PM
  3. Hiross Hirange Close Control Unit
    By garyjh24 in forum Air Conditioning
    Last Post: 06-05-2008, 10:07 PM
  4. Control scenario
    By Mike Hopkins in forum Technical Discussions
    Last Post: 14-09-2007, 11:25 AM
  5. New Capacity Control Solution
    By embrown in forum New Technologies
    Last Post: 30-12-2003, 01:33 PM
