Results 1 to 8 of 8
Thread: Carrier 30HR
    May 2008
    66
    802
    Carrier 30HR
    Hey guys,
    wonder if you would be so kind to give me some help (again)? whe where cold out on a chiller Carrier, model 30HR 502053-12
    build in 1974 and runs on R22. it has a volume of 104Ltrs.
    they have askt to do a big servive on this engine for the last time,because in 2015 they are going to change it.(law for R22 in europe)
    we dont have any booklets or flyers or other info for this kind of machine.it has being dormend for 23years and running for 12 years now. i need al info on engine service,valve's , gaskets and so on. manymany thanks in advance.
    Ice
    ps; i will post pfoto's asap
    Jul 2008
    London
    848
    May 2008
    66
    802
    Re: Carrier 30HR
    thnx M8,
    its a bit difficult to open each file separate but it gives me a good idea and start.
    Ice
    Jun 2006
    South Coast
    278
    23
    Re: Carrier 30HR
    Due to not having done 15 posts this site won't let me post a URL. so go to Carrier's web site.
    eto.carrier.com/lit.asp
    Somerset
    69
    4,707
    Re: Carrier 30HR
    Hey Ice!
    I am sure when Gibbo reaches 15 posts, he will be able to help us all!
    In the meantime try the link below.
    If necessary search 30HR.
    http://www.commercial.carrier.com/co...0_QRYY,00.html
    good luck Grizzly
    Aug 2001
    1,046
    Re: Carrier 30HR
    From about the late 1970s, Carrier took over Le Compressor Frigorifique (LCF, now the Carrier factory at Montluel in Lyons).
    Some 30HR chillers were made in France from that period, however it's probable that in 1974, your chiller was made in the USA.
    The name plate should tell you, plus the wiring will be in Yellow cable if its American. (French-made models were wired in red cable).
    The reason for all this is that the two model s will be different.
    1. Control schematic wiring differs.
    2. Part numbers will be different - not always interchangeable.
    3. Water flow rates for US models will be in US gallons (NOT the same volume measure as a British Imperial Gallon)
    Good luck if you can locate parts, but after 35 years it may mean that you will need to make your own.
    I would strongly urge you not to disturb any gaskets on the evaporator tube sheets unless you have no choice and they are shot - they are VERY difficult to replace. Additionally, because the water enters and leaves the evaporator at the top, it is prone to collecting debris in the bottom of the shell. Assume that there is a layer of filth in the base of the evaporator. If you don't get it all out, you will probably have poor evaporating conditions - 30 HRs were well known to flood back for this reason.
    On the plus side, the 06E compressor hasn't changed much and they can be rebuilt on site if you are careful.
    Hope this helps.......
    Somerset
    69
    4,707
    Re: Carrier 30HR
    Icecube
    A big thank you to Argus for such an informative post.
    Because of his useful info I can help further!
    Follow the link below for the Service Manual on the carrier 06D - 06E & 06CC Compressors.
    Good Luck Grizzly
    http://www.mediafire.com/?fnc2rn12xn2
    May 2008
    66
    802
    Re: Carrier 30HR
    Hey Guys,
    many-many-many thnx to you all.
    it always give me great plesure to work on the old engine's. they are so strong. we are debating on a overhaul to a newer refrig type.all suggestions or recommandations are welcome.
    to Gibbo, big Welcome on the forum.hope to hear from you regulairly.
    thnx again , Ice
  1. Replies: 12
    Last Post: 27-03-2011, 04:12 AM
  2. Carrier Chillers
    By Ed Burris in forum Technical Discussions
    Last Post: 27-03-2010, 02:00 AM
  3. Geoff in NY ~ Carrier Parts
    By Futsal1st in forum Trouble Shooting
    Last Post: 30-12-2009, 04:07 AM
  4. Help identifying carrier HiWall dom. split
    By paul_h in forum Air Conditioning
    Last Post: 12-12-2008, 09:12 AM
  5. Replacing a pari of compressors ona Carrier 30HR 121
    By Sanshinman in forum Commercial
    Last Post: 06-11-2008, 06:50 PM
