Thread: R123
    Jan 2009
    India
    42
    13
    R123
    Ho to recover the R123 from the system?
    11,025
    Re: R123
    Get an empty R123 cylinder and evacuate it.
    Connect it to the system and let the vacuum pull the R123 out.
    Repat with more cylinders if needed.
    Jul 2008
    London
    848
    Re: R123
    Repeat with more cylinders if needed.
    R123 is a nasty refrigerant so it isn't quite that simple even though the theory is correct
    Jan 2009
    India
    42
    13
    Re: R123
    This method is not perfect.I recovered the R123 by push&pull method.
    11,025
    Re: R123
    So why did you ask the question and what quantity were you dealing with?
    495
    21
    Re: R123
    you can poured it into a drum
  1. Retrofitting R11 to R123
    By mak_04 in forum Trouble Shooting
    Last Post: 03-10-2008, 04:18 PM
  2. Which Oil can be used with R123?
    By mak_04 in forum Refrigerants
    Last Post: 18-07-2008, 04:21 PM
