Thread: RS21 service manual needed
26-01-2009, 07:44 AM #1
Hi ! I search RS21 service manual.
I would like replacement evaporator.
(The main defrost heater resistor infinite ohms).
26-01-2009, 09:18 AM #2
28-06-2009, 12:24 PM #3
Re: RS21 service manual needed
I have an RS21JLBG which keeps shorting the main house fuse every time I switch it on. I have replaced the defrost sensor and the TOC, however both gave the correct Ohms reading but the defrost sensor was the white cap now replaced by black cap. Any way I have traced the short to the main defrost heater. The unit only trips when the main defrost heater plug is engaged. As both the main and the tray heater are in series I disconected the tray heater first and checked the Ohms (2.1) so this seems that the tray heater is OK. Can any one give me advice on replacing the Main Defrost Heater, I can purchase off e-bay. Also since this shorting fault the digital display is not working only showing a vertical bar illuminating on one of the 8s (upper bar) of the "Fridge Temp" display I understand this to be a fault code ??? Is this correct ?? Or is the PVCB blow as well??
Carrier 30GX Service Manual Required
By Hatchy in forum Refrigeration BooksReplies: 25Last Post: 05-11-2010, 07:58 PM -
T-292 EliteLINE Operation & Service Manual
By Dave1 in forum TransportReplies: 2Last Post: 08-07-2008, 08:15 AM -
daikin service manual help
By omurcelik in forum Air ConditioningReplies: 2Last Post: 28-05-2008, 01:42 PM -
SL/SB-400 Pump Down Procedures
By absolute-zero in forum TransportReplies: 1Last Post: 29-01-2008, 09:27 PM -
Carrier 40GKX028 service manual needed
By Ireland in forum Air ConditioningReplies: 6Last Post: 08-02-2007, 07:06 PM
