    Nov 2006
    Poland
    91
    Grasso SP2 two-stage ammonia screw compressor package.
    Hello guys!
    I have a question regarding Grasso SP2 two-stage ammonia screw compressor package - could someone tell me about advantages and disadvantages of it in comparison with systems with booster compressors?
    For these guys who do not know what Grasso SP2 package is - this machine consists of two independent screw compressors (one for first stage and one for the second stage) with two electric motors mounted on a common frame with a common oil system (a common oil separator).
    Thanks for any ideas.
    Regards.
    Jacek
    3,358
    Re: Grasso SP2 two-stage ammonia screw compressor package.
    Jacek ,
    System you have or refer to has a booster compressor ie first stage .
    What i think you are refering to is seperate 2 stage system with intercooler .
    Cant see much benefit for Grasso SP2 unless you are wanting very low tempreture system of say below -45 deg C .
    Mycom programe shows same performance for single stage economized 200L as 2016LSC compound screw ( Which is basically same as grasso screw but bolted together using 1 elec motor ) .
    Conditions of -33 deg C SST / + 35 deg C SCT .
    Grasso advantage
    No intercooler required
    Less components in system ( cheaper installation ) .
    Side load into interstage as well as economizer for subcooling
    Disadvantage ( compared to single stage economized ) .
    2 elec motors to maintain as well as electricals
    2 shaft seals to leak
    2 compressors to overhaul
    Harder to incorporate redundancy in case of breakdown .
    Probably only suited to very low temp application , otherwise why not single stage / economize plant ?
    If first stage comp is damaged any debris will go into second stage compressor
    Maybe you could give a bit more info as to conditions and application
    Nov 2006
    Poland
    91
    Jacek ,
    Grasso advantage
    Hello Ranger1.
    Many thanks for your reply.
    Telling about comparison, I had the difference between Grasso SP2 machine (or Mycom) and the plant with, let's say, two compressors (one high-stage and one low-stage - a booster compressor) in mind... I'm not talking about the one-stage compressor with the economizer port.
    Could you possibly provide me with the brief comparison?
    I hope I express my thoughts in a clear way.
    Thanks one more time.
    Jacek
  1. Grasso - 9 cylinder Compressor - Ammonia
    By rlmts in forum Industrial Compressors
    Last Post: 04-10-2010, 07:39 PM
  2. Two stage ammonia system
    By Samarjit Sen in forum NH3
    Last Post: 20-01-2010, 11:47 AM
  3. Compressors - screw or reciprocating?
    By Josip in forum Industrial Compressors
    Last Post: 27-01-2009, 10:36 PM
  4. Grasso screw comp unit acad drawings
    Last Post: 07-09-2008, 07:19 PM
  5. ammonia refrigeration
    By deepakrbhat in forum Refrigerants
    Last Post: 23-04-2004, 12:07 AM
