Results 1 to 13 of 13
    Jan 2008
    Rickmansworth
    47
    Frick shaft seal leaking
    I have a large Frick machine(cant remember exact model) that the shaft seal leaks on.
    The history is, the seal was suspect to be leaking, so we replaced the seal with a new one the customer had on site. However this seal had been on site since instal(15 years sitting on a shelf).
    I thought after replacing the seal and that it started to leak almost straight away that the housing o-rings could have been affected due to sitting on a shelf for 15 years, so i changed the o-rings for new.
    Ammonia still leaking from shaft seal.
    On replacing the seal i followed the instructions and didnt find it that hard, so dont think i've done anything wrong.
    Your thoughts would be very benificial.
    Ian
    Jul 2007
    Czech
    61
    374
    Re: Frick shaft seal leaking
    Hi, Ian B, I suspect you that you badly fitted washer spring. What number you compressor.
    Greetings Josef
    Jan 2008
    Rickmansworth
    47
    Josef
    I think the model number is
    Frick Model RWB 11 316. Hope this helps. Are you talking about the large spring washer? Does it matter which way round it goes?
    Ian
    Jul 2007
    Czech
    61
    374
    Hi, RWB II 316, so much depends, must push for the center, not on the edge
    Jul 2007
    Czech
    61
    374
    Send PM and email, your model compressor TDSH 283
    Jan 2006
    Valrico, Florida
    509
    Depending on who installed the seal and how he installed it could be the cause of the new seal leaking; was an alignment done or was it just pressurized, and the leak remained?
    Jul 2006
    73
    865
    26
    If the seal is old it could have rubber parts that react with the high solvency oil we use today. This usually takes some time, but it is a possibility.
    Somerset
    69
    4,698
    Hi Ian.
    Just a long shot I know!
    And it might be a silly question.
    But did you spin the compressor back up after fitting the shaft seal.
    Or did you just resign yourself to the fact that there was a problem?
    It may sound silly but I have reseated many leaking seals by running the compressor for a short while.
    Many newly installed seals will leak if.
    Insufficient oil was applied to the seal faces whilst installing the seal.
    Don't feel offended if you are already aware of this as it is not always explained nowadays.
    How important to keep the seal faces clean and well oiled!
    Feb 2007
    58
    158
    How well did you inspect the carbon seal before installation?
    Not just the face either.
    I had a crack running around the side of a crane seal for a Howden. Only spotted it while oiling the 'O' ring before pushing it on the shaft. As I oiled the inside of the carbon/'O' ring i noticed oil oozing thru to the outer edge, on inspection it turned out to have a crack 3cm long.
    You say that seal is 15 years old, could it have been dropped in that time?
    I make more of a point of inspecting parts now - even from sealed boxes.
    Steve
    Sep 2008
    United States
    59
    57
    I had a Frick RWB-40 that had seal leak issues, after 2 seal replacements in the course of a year it was determined that the compressor thrust bearings had worn enough to cause a new properly installed seal to leak. Just another area to consider. Also a compressor oil with seal conditioners is a good idea for older compressors. I use Camco 717-SC oil with good performance results.
    Jul 2007
    Czech
    61
    374
    Hi, many are here writes about "O" ring, I believe that the composition 15 years ago was more valuable than today
    Apr 2002
    Nova Scotia, Canada
    55
    22
    Hi all
    In the past I have had to operate the oil pump for a minute to get the seal to seat before first start up after seal replacement. After machine had run there wasn't any leaking. If the machine has been run, check the hot alignment and shaft end play, shouldn't be more than .003".
    Vinesy's Avatar
    Vinesy Guest
    Ian as long as you lubricated the seal on installation - run for 30-50 hours to bed in, it should be fine - all shaft seals need to bed in
  1. Frick Premature Seal Failures
    By Steve Wright in forum Industrial Compressors
    Last Post: 11-06-2010, 02:34 PM
  2. Help needed in Venezuela.
    By El Tel in forum Industrial
    Last Post: 15-03-2010, 10:54 PM
  3. Need info on the shaft seal system for scotsman
    By The MG Pony in forum Commercial
    Last Post: 17-03-2008, 02:02 AM
  4. Leaking X430LS shaft seals
    By reefermadness in forum Transport
    Last Post: 02-04-2006, 08:00 PM
  5. Bock AM5 compressor's shaft seal failiure
    By Gareth in forum Trouble Shooting
    Last Post: 05-04-2004, 09:12 PM
