Thread: Pipe diameter selection problem
10-01-2011, 09:27 PM #1
Hi Guys, I have a problem with a VRF system - it's consisted of two 45kW outdoor units working in parallel. The calculation software says that the main pipes should be 38mm/22mm, but here in Bulgaria we don't have 38mm copper pipe! So the question is - should I use 35mm or 42mm pipe?! The pipe run will be 20m long, 15m in vertical and 5m horizontal. Thank you in advance for your help!
11-01-2011, 03:17 AM #2
Re: Pipe diameter selection problem
Hi, I think you need give SST/Gas/Unit location
11-01-2011, 07:14 AM #3
11-01-2011, 08:24 AM #4
design conditions requd :
evaporating temp
condensing temp
refrigerant used
capacity of each compressor
BASED ON THE DATA THE PIPE SECTIONS CAN BE CALCULATED
11-01-2011, 09:44 AM #5
it does not matter,use what ever you can.
mmm 7/8 liquidmmm to beer or not to beer...........lets drink breakfast
Pipe diameter, real life and theory
By gwm121 in forum FundamentalsReplies: 8Last Post: 24-10-2009, 04:53 PM -
Samsung Vivace Problem AQV24VBCN
By goldpau in forum Air ConditioningReplies: 0Last Post: 18-09-2009, 06:28 PM -
Chilled water pipe sizing?
By monkey spanners in forum Technical SpeculationsReplies: 4Last Post: 07-08-2009, 04:31 PM -
Saunier Duval Problem
By mallorcanangel in forum Air ConditioningReplies: 1Last Post: 10-07-2009, 01:26 AM -
Furance problem
By ALONEI in forum Trouble ShootingReplies: 10Last Post: 14-05-2008, 11:32 AM
