Page 2 of 2 FirstFirst 12
Results 51 to 52 of 52
  1. #51
    Apr 2001
    79
    5,071
    35
    Re: H/p L/P switch settings
    Quote Originally Posted by rdocwra
    Hi all,
    Just a quick list of approxomate pressures in response to Bernards original post. Obviously these are approx & ambients could change.If i have worked these out wrong can someone let me know
    Raymond
    Gas Type, HP, LP@0coil, LP@-10 Coil, LP@-30 Coil.
    R12, 118, 30, 17, 1" vac.
    R134, 125, 28, 14 , 1" vac/
    R22, 190, 58, 36, 9.,
    R502, 215, 67, 36, 14.
    FX10, 220, 68, 44 , 13,
    FX56 125, 27, 15 , 1" vac,
    R404 230 , 72 , 48, 14,
    R407 220, 50, 32 , 13,
    R410 320 , 100, 68, 24,
    R507 240, 76 , 48 , 16,
    Saturated temperature version of the same list:
    Gas Type, HP, LP@32F/0C Coil, LP@14F/-10C Coil, LP@-22F/-30C Coil
    R-whatever, 99F/38C, 32F/0C, 14F/-10C, -22F/-30C
  2. #52
    leonmartinharms's Avatar
    leonmartinharms Guest
    1.you take the max avarage ambient for the region,say 35 deg.
    2.take condensor td,say 15k.
    3.add 5psi for safety
    add 1,2 and 3 =35+15+5=55 degrees. this temp should match the pressure on hp gauge.
    That applies to all gasses
  1. flow switch connection
    By afeef in forum The Trail of Tears
    Last Post: 23-12-2009, 06:55 PM
  2. Supermarket Refrigeration System's Settings
    By monsker in forum Supermarket Refrigeration
    Last Post: 10-04-2006, 02:18 AM
  3. RCV and HIGH PRESSURE SWITCH
    By abbasi in forum Fundamentals
    Last Post: 22-03-2006, 08:51 AM
  4. shower switch fault !
    By Krups in forum Electrical
    Last Post: 19-10-2005, 09:10 PM
  5. Oil Pressure Switch
    By Abe in forum Commercial
    Last Post: 15-03-2003, 11:18 AM
