Results 1 to 2 of 2
Thread: A quick question re; diy a/c
16-01-2009, 05:12 PM #1
Hi guys,
I searched but found nothing difinitive on this.
I assume the diy a/c's which use the pre-charged lines and clunk click connections are still legal to install.
What about the many systems seen on line described as self install which supply the pre-insulated / flared lines?
Some of these actually SHOW the lines being purged after being connected - illegal surely!
Also, what if the diyer at least tries to be competant and borrows / hires a vac pump, so they are not actually purging the lines? What's the legality of that?
Thanks in advance
16-01-2009, 07:06 PM #2
Re: A quick question re; diy a/c
As far as I know at the moment the only legal requirement is that you do not release refrigerant into the atmosphere.
Hopefully Argus will follow up on this thread as well.Brian - Newton Abbot, Devon, UK
Quick question
By 2007eng in forum Air ConditioningReplies: 2Last Post: 02-11-2008, 11:26 PM -
Quick R23 question.
By Targ in forum RefrigerantsReplies: 2Last Post: 23-04-2006, 09:16 PM -
Quick question about using a fridge in an RV
By Definca in forum FundamentalsReplies: 1Last Post: 19-07-2005, 07:43 AM
