Results 1 to 20 of 20
Thread: Weight
15-01-2009, 11:13 PM #1
Weight
Is it a legal requirement to have the amount of gas in each system recorded
15-01-2009, 11:46 PM #2
Re: Weight
Yes it is; and the type.
It should all be kept in the equipment register.Brian - Newton Abbot, Devon, UK
16-01-2009, 03:24 PM #3
Re: Weight
and the owner and the location and the last technician ho serviced the plant,....no???
Ice
16-01-2009, 04:34 PM #4
16-01-2009, 07:18 PM #5
Re: Weight
F Gas Regulations
16-01-2009, 07:27 PM #6
16-01-2009, 11:29 PM #7
Re: Weight
My understanding of the question was for each system ie every system irrespective of size,gas etc. F-gas relates to only those gases covered and only for systems above 3kg, which is why I asked for a link.
17-01-2009, 12:51 AM #8
Re: Weight
I agree, I have the misfortune of looking after a site with over a hundred versatemp units, and was informed then that the register only applies to systems 3kg and above.
I guess that we shall all find out when we sit the new safe handling exams!!
24-01-2009, 12:17 PM #9
Re: Weight
Is there a chart for pipesize- length - bends to allow me to calculate the weight Kg of gas in pipework.
24-01-2009, 12:39 PM #10
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Weight
Don't you think that gas weight depend on density, which depends on temperature. And, what with mixture of gas and liquid in pipe?
You could use Coolpack software for calculation of liquid and gas flow in pipes and fittings! From that you could estimate/calculate weight.
24-01-2009, 01:27 PM #11
Re: Weight
To enable the calculation of weight Kg in pipework (R407C) to be added to the condenser - compresser. Is there not a chart giving the weight for various diameters of pipes listing the kg/m in a liquid line.
24-01-2009, 02:03 PM #12
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Weight
If you have Excel, it is easily calculated from pipe dimensions and density.
Tables you could find here at page 11:
http://www.suva.dupont.ca/pdf/RefrigPipingHandbook.pdf
24-01-2009, 02:05 PM #13
Re: Weight
Found information on manufacturers website giving pipe size curves and the Kg /m required
24-01-2009, 02:13 PM #14
Re: Weight
Many thank for you help nike123
25-01-2009, 07:49 AM #15
Re: Weight
25-01-2009, 07:53 AM #16
Re: Weight
That's correct and 6 kg and above for factory hermetic made units (like monoblocs, chillers,...).
I'm a jury member and chairman of the Jury in th Dutch speaking part of Belgium, so if you have questions...
You can find everything you need to know in the new EN378-2008.Last edited by Peter_1; 25-01-2009 at 08:00 AM.
25-01-2009, 09:49 AM #17
Re: Weight
25-01-2009, 10:04 AM #18
Re: Weight
Link: EN378-4:2008, Appendix D. - D5
Translated from Dutch: The applications must be controlled on leakage within 1 month after repair of the leak to ensure that initial repair was effective.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
29-01-2009, 06:16 PM #19
Re: Weight
Take a look at this calculator / spreadsheet off the Defra website.
http://www.defra.gov.uk/environment/...y/quantity.htmIf in doubt read the instructions. If still in doubt follow them.
29-01-2009, 07:50 PM #20
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Light- weight Compressor's No Oil No Bearings
By chillerman2006 in forum New TechnologiesReplies: 34Last Post: 03-08-2011, 03:47 PM -
Need the weight apx of a Scottsman Ice flaker
By The MG Pony in forum CommercialReplies: 2Last Post: 07-03-2008, 12:55 AM -
how to calculate weight of refrigerant
By steven86 in forum FundamentalsReplies: 11Last Post: 13-09-2007, 09:05 AM -
Fan model for system optimization
By autt in forum System OptimizationReplies: 8Last Post: 31-03-2007, 05:34 AM -
Load Calculation / Comaprison
By herefishy in forum Technical SpeculationsReplies: 11Last Post: 04-03-2002, 09:21 PM
