Results 1 to 11 of 11
Thread: Frick TDSH 233L
14-01-2009, 12:37 PM #1
Frick TDSH 233L
Hi Guys
Could someone give me the allowable axial and radial end play for this machine.
Thanks in advance
J.D.
14-01-2009, 01:01 PM #2
Re: Frick TDSH 233L
Radial?
14-01-2009, 01:44 PM #3
Re: Frick TDSH 233L
I'm testing the end play due to some seal problems in the machine. So I need to check the Up, down and side to side movement as well as in and out
14-01-2009, 04:49 PM #4
Re: Frick TDSH 233L
I think if it moves side to side you might be in trouble...
14-01-2009, 06:26 PM #5
Re: Frick TDSH 233L
J.D.
Email me.
I may be able to help?
14-01-2009, 07:58 PM #6
Re: Frick TDSH 233L
Hello jd the end play is .025"/.039" on frick tdsh 233, any other problems ,let us know might be able to help
15-01-2009, 12:27 AM #7
Re: Frick TDSH 233L
Thank you for all the input
06-02-2009, 11:05 AM #8
Re: Frick TDSH 233L
Hello J.D.,
If you have a leaking seal, did you check the allignment of compressor and motor?
We use laser allignment to check. That often work to avoid seal leakage.
Greets,
Bart.
06-03-2009, 11:33 PM #9
Re: Frick TDSH 233L
Hi, Can anybody tell me if there is a type FRICK compressor PDSH 355L?
I know TDSH 355L exists but can't find anything on PDSH
Thanks in advance
07-03-2009, 07:58 PM #10
Re: Frick TDSH 233L
Koel Hi, I know just TDSH, TDSB, GDSH 355 and TDSL, GDSL 283
29-07-2009, 08:04 AM #11
Re: Frick TDSH 233L
Yes there is a PDSH its a specical compressor for the YPS devison of frick. They are cast steel machines instead of cast iron.
Frick compressor RXF 101-H
By PaulZ in forum Industrial CompressorsReplies: 11Last Post: 19-02-2009, 02:29 AM -
FRICK TDSH 233 Slide Valve and guide damaged
By 404cab in forum Industrial CompressorsReplies: 9Last Post: 30-07-2008, 11:24 PM -
Ammonia Circulation rate - by Frick/ Vitler
By smpsmp45 in forum NH3Replies: 12Last Post: 16-06-2008, 10:06 AM -
Frick Quantum Panel
By LEE40 in forum Trouble ShootingReplies: 4Last Post: 27-03-2008, 05:24 PM -
old frick system monitor
By rasgrant in forum NH3Replies: 5Last Post: 17-01-2007, 06:15 PM
