Thread: one door up right problem
11-01-2009, 03:39 PM #1
unit status:
134a suction 25 psi head 175
clean condensor, new evap fan , new tx valve, clear sight glass. running at 52 degress to 47 dgrees
tx valve is one turn away from wide open
Any ideas?
11-01-2009, 03:53 PM #2
Re: one door up right problem
Gary will be along soon with a list of measurements you really should take before posting!
In the meantime,Shut the valve down 1 turn and see.
11-01-2009, 04:00 PM #3
11-01-2009, 04:01 PM #4
11-01-2009, 04:49 PM #5
Put the valve back to its correct setting and then give us a set of readings after it has stabilized.
MFI AMP6855 defrost problem
By gliderpilot47 in forum DomesticReplies: 4Last Post: 12-01-2011, 12:11 PM -
A strange problem
By MuhengineeR in forum Air ConditioningReplies: 14Last Post: 27-10-2010, 05:21 PM -
problem with GE air con power problem
By Richie101 in forum Air ConditioningReplies: 6Last Post: 05-11-2009, 04:00 PM -
Furance problem
By ALONEI in forum Trouble ShootingReplies: 10Last Post: 14-05-2008, 11:32 AM -
York Chiller Excessive Purges Problem
By imranmd in forum CommercialReplies: 5Last Post: 07-03-2008, 05:13 AM
