Thread: Dry Rooms
11-01-2009, 05:58 AM #1
Dry Rooms
Has any one any experience of putting up dry rooms for very very low humidity. What type of doors are used? any special considerations?
11-01-2009, 05:19 PM #2
Re: Dry Rooms
I've worked on them but not designed or installed....
This website shows some basic details which may be of use to you..
http://www.dryrooms.com/dry/construction.htmlBrian - Newton Abbot, Devon, UK
12-01-2009, 08:00 AM #3
Re: Dry Rooms
We installed and made in the past some wood dryers.
The doors were the same as used in cooling rooms.
You only need an airtight room.
But it can much cheaper with sliding doors because those doors opens rarely. orLast edited by Peter_1; 12-01-2009 at 11:58 AM.
12-01-2009, 08:15 AM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Dry Rooms
Ignore! .......
13-01-2009, 03:35 AM #5
Re: Dry Rooms
Dear Peter1, Nice Photos . The doors - Hinged type. How those were made?
13-01-2009, 06:44 AM #6
Re: Dry Rooms
It were in fact more doors like this Oner ail for all the doors, so only one door could be used at once.
On the rail was a simple sliding system with a lift-up device we made ourself (not my idea but seen elsewhere)
The door felt in 4 inclined steel hooks so that the gaskets closed firmly the door.
We used the rails of a Belgium manufacturer Rob www.rob.be
http://www.rob.be/documenten.asp?l=nl
What do you want to dry?Last edited by Peter_1; 13-01-2009 at 06:48 AM.
14-01-2009, 11:53 AM #7
Re: Dry Rooms
Is this the right section smpsmp45
BT Comms rooms
By stuartwking in forum Air ConditioningReplies: 15Last Post: 20-04-2008, 05:40 AM -
Fcu Inside Electrical/ups Rooms
By popi in forum Air ConditioningReplies: 6Last Post: 19-03-2008, 01:54 PM -
Porkka cold rooms
By Andy AC in forum CommercialReplies: 6Last Post: 29-08-2007, 08:14 AM -
data rooms
By techni in forum Air ConditioningReplies: 17Last Post: 25-05-2007, 10:20 PM
