    ding dong's Avatar
    ding dong Guest
    carrier 30GK 085
    I have a problem with a carrier chiler model 30GK 085
    this chiler can work with two set points i need to now how can i control it.
    i now i have to conect or disconect two connections.
    Jun 2006
    South Coast
    278
    Re: carrier 30GK 085
    How are you controlling the chiller, local or remote control.
    If you check the wiring to the following terminals this will help to tell you how this chiller is controlled remotely..
    30 -31 remote alarm
    32 -33 remote start stop
    34 -35 remote water loop pump contacts or flow switch.
    63 -64 remote cooling or heating
    65 -66 remote cooling setpoint
    Hope this helps
    Nov 2007
    Peoples Republic of Geordie Land
    47
    Does any of you know how to set the temperature down low than pre set +3.3*C. I have a customer with a 30GK 085 which would like to run it at -3*C. They have added glycol within the liquid mix.
    I have contacted Carrier last week but are still awaiting there response. Do i need to change components to the unit for it to run sub zero?
    Jun 2006
    South Coast
    278
    Quote Originally Posted by CoolKids View Post
    According to the IOM for this unit to operate at -3C you will require some factory options either option 5 or 6 you will need to wait for Carrier to return your call to confirm which one you will need as for the glycol you have added you do realise you will reduce the capacity of the chiller, how much depends on the amount of glycol. Who did you call at Carrier ?
    Do you have a controls manual?
    http://eto.carrier.com/litterature/cm/13411.pdf
    Jun 2006
    South Coast
    278
    Forgot to add that Carrier Service would be needed as well to reconfigure the Service Configuration Software in the chiller control board.
    Nov 2007
    47
    Evening
    Thanks for all the help.
    We have the IOM and are aware the cooling capacity will be reduced depending on the glycol/temperature set. I spoke to Chris@ Carrier tech this morning and he cannot find any options that will alter the set points for the unit to run colder equired setpoint -3*c. He was going to speak to one of the Carrier engineers to see how to carryout the procedure. I'm still awaiting the call.
    Jun 2006
    South Coast
    278
    Option 5 (Medium Brine) allows leaving temperature from +5C to -6C at minimum requires reselected Electronic Valves and varnished compresser terminal plates.
    Option 6 (Low Temp Brine) allows leaving temperature from -6C to -10C all of the above plus modified cooler and increased cooler insulation.
    Also if the chiller is to be run at ambients below 0C then Option 28 is needed which is Condenser Varifans (variable speed fan motors) 1 per circuit.
    As you can see its a bit more than just adjusting setpoints.
  1. Replies: 12
  2. 30GK carrier chiller wiring diagram
    By ash_sabi2006 in forum Electrical
    Last Post: 20-05-2010, 04:26 PM
  3. Carrier Chillers
    By Ed Burris in forum Technical Discussions
    Last Post: 27-03-2010, 02:00 AM
  4. Help identifying carrier HiWall dom. split
    By paul_h in forum Air Conditioning
    Last Post: 12-12-2008, 09:12 AM
  5. carrier remote
    By superswill in forum Trouble Shooting
    Last Post: 26-04-2006, 09:17 PM
