Results 1 to 2 of 2
Thread: Critical temperature
09-01-2009, 08:20 AM #1
hı guys,
I need to know what the critical temperature is for refrigerants.For example the critical temperature is 101 deg. for R-134A.If the gas temperature exceeds over 101 deg. (like 150 deg.) in the system,what will happen? does it lose physical and thermal properties?
ı am waiting for your help..
09-01-2009, 08:29 AM #2
Re: Critical temperature
above this temp the gas can no longer condense into a liquid, only vapour is present above this temp. Refrigeration processes can exist sub critical (normal system) or transcritical, this means compressing a gas above its critical temp, rejecting heat through means of a gas cooler and then lowering the pressure so as to bring it below its critical temp and condense into a liquid. Transcritical is used especially on R744 (Co2) systems...and she said "give it to me you big fridgie"
Superheat and Subcooling
By Chunk in forum FundamentalsReplies: 42Last Post: 15-01-2011, 01:24 AM -
LG heat pump problem
By back2space in forum Heat PumpsReplies: 132Last Post: 01-02-2009, 11:23 PM -
Thermo King OptiSet
By REEFER-TEK in forum TransportReplies: 4Last Post: 06-12-2007, 07:23 PM -
Article in ACH&R News
By Gary in forum FundamentalsReplies: 8Last Post: 20-05-2003, 12:27 AM
