    Apr 2007
    izmir
    38
    Question Critical temperature
    hı guys,
    I need to know what the critical temperature is for refrigerants.For example the critical temperature is 101 deg. for R-134A.If the gas temperature exceeds over 101 deg. (like 150 deg.) in the system,what will happen? does it lose physical and thermal properties?
    ı am waiting for your help..
    Jul 2001
    Sydney, Australia
    753
    Re: Critical temperature
    Quote Originally Posted by cakabo28 View Post
    hı guys,
    above this temp the gas can no longer condense into a liquid, only vapour is present above this temp. Refrigeration processes can exist sub critical (normal system) or transcritical, this means compressing a gas above its critical temp, rejecting heat through means of a gas cooler and then lowering the pressure so as to bring it below its critical temp and condense into a liquid. Transcritical is used especially on R744 (Co2) systems
    ...and she said "give it to me you big fridgie"
  1. Replies: 12
  2. Superheat and Subcooling
  3. LG heat pump problem
    By back2space in forum Heat Pumps
    Last Post: 01-02-2009, 11:23 PM
  4. Thermo King OptiSet
    By REEFER-TEK in forum Transport
    Last Post: 06-12-2007, 07:23 PM
  5. Article in ACH&R News
    By Gary in forum Fundamentals
    Last Post: 20-05-2003, 12:27 AM
