Results 1 to 20 of 20
Thread: Broken compressor
28-03-2004, 12:48 PM #1
Re: Broken compressor
Originally Posted by rbartlett
So.. am i a good engineer now?
It was running this way for some days.
It was due to a sump full of WD40 that it was running that smooth.
Sure I have WD40: a good friend of me is working at the sole Belgium importer of that stuff.
Ever tried this ? Spray WD40 on the thread of a light bulb, screw it in the socket, put in the wall socket and immerse the bulb completely under water. Light will light under water and normally, no safety device will trip at all.
Try at your own risk but that's the way he always impresses customers.
28-03-2004, 07:08 PM #2
Originally Posted by Peter_1
But thanks for the info. If I ever need to do some underwater illumination, it sounds like just the thing! Maybe all those people electrocuted by hair dryers in the bath should be giving the things a good spray with ol' WD40 before jumping in the tub!
RogLast edited by RogGoetsch; 29-03-2004 at 03:18 AM.
28-03-2004, 09:03 PM #3
29-03-2004, 08:28 AM #4
INOX, any of you guys other then aussies heard of inox? its based on lanolin and made in australia - i prefer it to a can of wd40, seems thinner and gets into all those nice rusted nuts and bolts good, available in a bottle or pressure spray can like wd40. also great for bearings frees them up a treat compared to wd which makes them feel binding through the tacky oil.
not suitable to sliders etc as Rog approach is still the best for those applications."Old fridgies never die, they just run out of gas!"
29-03-2004, 08:28 PM #5
[QUOTE=Bones]INOX, any of you guys other then aussies heard of inox? its based on lanolin and made in australia -
yes but they were never the same since hutchence topped himself
cheers
richard
29-03-2004, 10:17 PM #6
When I was a mechanic and I was troubleshooting an electrical problem I always fixed the problem with WD 40 and never had to replace any defective electric control. Boy thats good stuff LMAO
Roger
29-03-2004, 10:19 PM #7
Richard... A little dab il do ya!
Roger
12-09-2004, 02:28 AM #8
Originally Posted by shogun7
and it will even help that. Wes MaxfieldWes Maxfield
11-09-2004, 09:21 PM #9
are you mad!!!!
11-09-2004, 09:27 PM #10
peter,did you buy new parts or stick them back together?
can overfilling/overcharging damage a compressor?
By fredjchavez in forum Trouble ShootingReplies: 10Last Post: 12-02-2009, 10:30 AM -
Compressor pumping efficiency
By shogun7 in forum FundamentalsReplies: 0Last Post: 25-02-2004, 10:50 PM -
One Half of a Part Wound Compressor Motor is Burnt
By aygul in forum Trouble ShootingReplies: 2Last Post: 25-08-2003, 11:11 AM -
Compressor failure...... cause
By herefishy in forum Technical SpeculationsReplies: 8Last Post: 06-12-2002, 12:15 AM -
Starting a compressor, and receiver questions.
By DaBit in forum Technical SpeculationsReplies: 9Last Post: 24-08-2002, 12:37 PM
