Thread: parat roller case
08-01-2009, 07:06 PM #1
parat roller case
hi,i'm thinking of buying a parat roller case to use as my day to day service box,the only thing is they are on average £180 pounds stirling!! just wondering if anyone in the uk knew of anywhere to pick them up a little cheaper?
regards ali.
08-01-2009, 07:14 PM #2
Re: parat roller case
What luck have you had in your Google searches for a cheaper find?
08-01-2009, 07:21 PM #3
Hi aliman
I got mine from RPW about £170.
Expensive I know but well worth the money, if you look after it it will last you a life time.
PP
08-01-2009, 07:23 PM #4
Thread moved to the correct section
08-01-2009, 07:37 PM #5
thanks p_p, i must go into rpw, gloucester to do a bit of bartering.as i did'nt know they stocked them!
08-01-2009, 07:34 PM #6
hi,cheapest was £182 from amazon for the classic roller.
08-01-2009, 07:40 PM #7
Ali
Like I said look after it and it will last you a lifetime, which in the long run makes it a cheap case.
Go on you know you can afford it!!!!!!!!!!!!
PP
08-01-2009, 07:43 PM #8
I dont think they stock them anymore but they will be able to get hold of one for you, as RPW nottingham did for me.
PP
crank case heaters in scroll compressors
By abbasi in forum FundamentalsReplies: 19Last Post: 03-08-2010, 03:04 AM -
Coffin Case Woes
By Stiff Nipples in forum Supermarket RefrigerationReplies: 25Last Post: 17-06-2010, 06:03 AM -
kys0r/warren produce case not cold enough
By shawn626 in forum CommercialReplies: 5Last Post: 28-09-2008, 02:52 PM -
a frozen book display case
By tempo in forum Technical DiscussionsReplies: 3Last Post: 15-08-2008, 07:20 PM -
cpc case controller
By dingo in forum Trouble ShootingReplies: 4Last Post: 09-04-2008, 09:35 AM
