Results 1 to 13 of 13
    Nov 2007
    singapore
    45
    Thumbs up Air conditioning
    Can anybody clear my doubt pls
    I believe that when the room attains the set temperature the thermostat will de energise the liquid line solenoid valve so that the the compressor will cut off through low pressure switch
    My doubt is if the compressor cut off in LP switch then how it will restart again when the room temperature starts increasing
    i heard that if the unit trips through LP switch, without resetting we cannot start the unit
    can anybody brief me how the cycle is controlled ill be thankful to you because iam weak in controls and i feel difficult to understand the control circuits
    regards,
    Balaji
    Split Croatia
    57
    6,151
    36
    Re: Air conditioning
    That depend on LP switch and used controller settings.
    You could have Lp switch with manual or automatic reset.
    You could also have control that needs manual resetting and other one that is automatically reset few times and after that you need manual reset.
    In case when pump down circuit is used (like your example) Lp switch is automatically reset.
    Nov 2007
    singapore
    45
    Hi nike,
    Thanks for your reply. i want to develop my knowledge in control circuits is there any reference book, if you have please forward to me. except you nobody reply to this thread why? I asked silly questions ?
    regards,
    Balaji
    Mar 2005
    u.a.e
    68
    169
    A question is a question,
    AND IT IS BETTER TO ASK THEN NOT TO ASK....
    What you asked is a pump down type system and when temperature satisfied the thermostat cuts solinoid and system stops by L.P, Normally this type of systems works with two L.P switches, One for the Pump down and second one for SAFETY CUT OUT, The second L.P swith set point is much lower then pump down L.P.
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by balaji View Post
    regards,
    Balaji
    Check my signature!
    Split Croatia
    57
    6,151
    36
    Hi nike,
    No, I don't have any book.
    Most of required knowledge you could gather by reading service manuals of equipment.
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by malik55 View Post
    To add to that, Pump down LP switch is automatically reset type and safety cut out switch is manually reset type.
    Nov 2008
    United Kingdom
    33
    Nike, check the posters signature name... and relax.
    To Balaji... try to use screwdriver for LP adjustment. It helps to understand how switch works.
    Nov 2007
    London
    461
    balagi, i could see the use of this type of control on a refrigeration plant but it will not cut out on low pressure as such just a differential pressure, if you had a system cutting out like this everytime it reached thermostat i can't see it being good for the compressor.
    Nov 2007
    singapore
    45
    Thank you guys atleast i received 8 replies, iam satisfied and i hope no need to go for two LP switch even a single LP with three set points can do that
    Mar 2005
    New Zealand
    43
    64
    Balaji, This is very straight forward, You are correct in saying that when the thermostat reaches temp it de-energises the solenoid and allows the compressor to pump down then cut out on the LP switch, when the thermostat calls for cooling again, the solenoid opens and, the pressure rises, closing the contacts of the LP switch and the copmpressor will restart. This type of control circuit is not always needed on a chiller but almost always on a freezer. The advantage of this circuit is if there is a great distance between the compressor and Evaporator, you do not need any cables running between as you can locate the Solenoid inside with the Evaporator. Hope this helps.
    Mar 2005
    u.a.e
    68
    169
    Different type of controls can do same things, A systems can pump downs by a thermostat and also by a L.P switch.
    Jan 2008
    India
    70
    171
    Normally LP is auto reset where as the HP will have to be manually reset.
  1. Air Conditioning Courses
    By stesmith1981 in forum Industrial
    Last Post: 09-03-2010, 06:33 PM
  2. Replies: 11
    Last Post: 13-08-2008, 01:22 PM
  3. Unique cooling system Port-A-Cool replaces air conditioning
    By LC-Europe in forum New Technologies
    Last Post: 30-01-2008, 08:29 AM
  4. Replies: 2
    Last Post: 01-07-2007, 04:30 PM
