    fierce_teapot's Avatar
    fierce_teapot Guest
    Fridge Freezers in cold locations
    Is it really true that if my normal cheap fridge freezer is in a very cold room (say 1-5 degrees C) that it might not freeze food very well? ...
    I have a feeling this is the case, as recently the freezer seems to have packed up and the past few days it has been very cold in that room.
    If this is true, why dont fridge manufacturers place a thermostat inside the freezer compartment?!
    Please help as Im wondering whether its worth phoning the manufacturer (some generic one, Coolzone) and seeing if my warranty can help.
    69
    10,503
    Re: Fridge Freezers in cold locations
    It can happen as there isn't enough temperature difference between the inside and outside of the unit.
    There have been various suggestions such as putting a low wattage light bulb inside the fridge to give it a false load.
    You could try calling the maker but I wouldn't hold your breath
    Also see....
    http://www.refrigeration-engineer.co...freezer+garage
    Split Croatia
    6,106
    7
    30
    Why don't you read your user manual? It is usually stated there that unit should not be in low temperature environment.
    Oct 2006
    1,848
    15
    Quote Originally Posted by fierce_teapot View Post
    I will exlain why this happens then you will know the answer.
    Fridge freezers are controled by the temp of the fridge alone ( if the fridge is at the correct temp then the freezer will be).
    Because this temp is controled in the fridge if the temp around the outside of the fridge drops below about 5 degC the fridge will turn off as normal but not turn on because it thinks it is cold enough at 5 degC.
    The trouble is the freezer then warms up to 5 degC aswell and you loose the stock.
    Some fridges have switches on them to allow for cold conditions and there are other tricks you can do as explained above, but for the most part they will not run correctly in low ambiant temps.
    Cheers taz.
  1. Hotpoint fridge not cold anymore.
    By tishybabe in forum Domestic
    Last Post: 01-10-2011, 03:24 PM
  2. fridge warm freezer cold?
    By babsnsarah in forum Domestic
    Last Post: 30-04-2011, 04:24 PM
  3. Zanussi ZD-33/11 fridge too cold
    By frozensolid in forum Domestic
    Last Post: 05-10-2008, 02:05 PM
  4. Are there 2 basic types of fridge freezers
    By K805sc1 in forum Fundamentals
    Last Post: 19-01-2008, 04:33 PM
  5. Freezer not cold enough, Fridge too cold
    By barrance in forum Commercial
    Last Post: 06-12-2001, 07:11 PM
