Thread: Pipe carrying capacity
05-01-2009, 07:17 AM #1
Hi All, is there a table available with approx liquid refrigerant weight (R22) per metre for various size copper pipe.
05-01-2009, 04:37 PM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Pipe carrying capacity
You could easily calculate for various pipes in Excel from pipe internal volume (internal radius^2 x Pi x pipe length) and specific weight of liquid refrigerant.
05-01-2009, 05:36 PM #3
unibar,
Here's alink to Heatcraft's Engineering Manual.
Click on: Heatcraft Engineering Manuals
Then: Engineering Manual
Page: 36
It's not in metric though.
http://www.hvacrinfo.com/loadcalcs.htm
05-01-2009, 09:16 PM #4
yeah this is true but all systems will have different operating characteristics so it is best to work out the charge as per refrigerant classification and model of the unit..
the only one that will be a constant will be water as there is no state change as such, only flow rate will vary depending on resistance..
06-01-2009, 05:12 AM #5
cable current carrying capacity
By nickruf in forum ElectricalReplies: 6Last Post: 23-05-2007, 04:22 PM -
R-407C and Coil Capacity
By glabah in forum RefrigerantsReplies: 5Last Post: 03-06-2006, 11:36 AM -
Cable current carrying capacity
By Abe in forum ElectricalReplies: 72Last Post: 25-09-2005, 10:23 PM -
TEV capacity related to pressure drop
By DaBit in forum CPU OverclockersReplies: 8Last Post: 06-12-2002, 05:11 PM
