Results 1 to 2 of 2
Thread: Refrigerant Requirement
03-01-2009, 07:33 AM #1
I am designing a CO2 evaporator coil for subcritical application. Does anyone know how to calculate the required CO2 amount (? kilograms). The duty of the evaporator is about 16kW.
many thanks,
14-04-2009, 09:06 PM #2
Re: Refrigerant Requirement
The first thing you need to know is the internal volume of the evaporator.
Then how are you managing liquid flow?
If you are aiming at some form of TXV feed: with a manageable superheat at least 10% and probably more of your evaporator is going to be devoted to warming the "dry" vapor...
Superheat and Subcooling
By Chunk in forum FundamentalsReplies: 42Last Post: 15-01-2011, 01:24 AM -
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
CARE refigerants by BOC
By dogma in forum RefrigerantsReplies: 8Last Post: 23-03-2010, 12:39 PM -
MHI FDCA400HKXRE4 Tech Info Please
By L.JT in forum Trouble ShootingReplies: 5Last Post: 23-08-2008, 11:00 PM -
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM
