Results 1 to 25 of 25
02-01-2009, 07:58 AM #1
Please help on DAIKIN rzq/FBQ125 !!!
Hello, i'm french. I don't speak english very well so excuse me.
I'm looking for the "big manual" for rzq 125. It is to know all code of the controller and the outdoor unit.
You can mail me information to nak210479@free.fr
Thank you !!!and happy new year 2009!!!!
Cédric
02-01-2009, 08:40 AM #2
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: Please help on DAIKIN rzq/FBQ125 !!!
Check here:
http://www.daikinac.com/landing.asp
And this is direct download!
02-01-2009, 12:23 PM #3
ok thanks.
My defrost is too long(11 min). In only 5 min max there is not frost. How can i modif this setting.
Cédric
02-01-2009, 12:30 PM #4
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
02-01-2009, 01:11 PM #5
because it is too long so when it is below 1° outside there is lot of defrost. the temperature does not arrive has go up, it consume more for nothing and it do not heat up, it defrost while it can be heating up.
I hope you understang what i try to write.
Cédric
02-01-2009, 01:33 PM #6
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
02-01-2009, 01:47 PM #7
it is not pas leaks. humidity is between 70and 80% but there is defrost when T° outside is 11°. And there is not frost !!!
02-01-2009, 09:01 PM #8
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
03-01-2009, 12:34 AM #9
In relation to your unit, you either have a refrigerant leak or the outdoor unit is short cycling.
If your indoor filters are blocked and the unit does not see a change in the return air temperature it may also go into a premature defrost..
03-01-2009, 06:59 PM #10
the outdoor unit is long cycle (16 03 03)
i have a thermometer inside my home but outside the indore unit. So the T° checked is that of the room.
03-01-2009, 07:00 PM #11
03-01-2009, 08:12 PM #12
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Short cycling at which Brunstar refers is when discharged air from outdoor unit doesn't freely goes out. Instead, some significant portion of that air rebates from surrounding obstacles and circulate again in outdoor unit heat exchanger, and therefore, efects outdoor air entereng temperature to be lower than actualy outside air temperature is. That causes uneccesary defrosting.
What you are refiring is page 155 of manual.
Temperatures about what you are speaking in your posts are not clear any more after last post. So, please measure again outdoor temperature and humidity and indoor temperatures at inlet and outlet of indoor units!
Also put your indoor units on high fan and temperature at max (30°C) and check temperatures after 5 min has pased. If needed, you could open windows partialy to alow that indoor units works at maximum power.
Also give us model# of indoor units. This is in order to calculate power emited from indor units and to evaluate proper functioning of outdoor unit!
03-01-2009, 08:40 PM #13
sorry it 16(26) 3 02
03-01-2009, 08:43 PM #14
OK, i take T° tomorrow.
Bye
Cédric
03-01-2009, 09:47 PM #15
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
07-01-2009, 09:17 PM #16
hello,
outdoor temp=-3.5°
humidity 80%
indoor aking for 21
temp is 20 no more
temp of indoor unit 41° and one defrost(11min)/H
I try tomorrow with asking 30°.
Thanks.
Cédric
07-01-2009, 10:50 PM #17
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
07-01-2009, 10:54 PM #18
with a coil temp of that i think that this unit is operating very well considering the ambient is -3.5 deg c.
that unit won't give you 14kw output at those temperatures but i think it is operating well for the conditions it is under.
What is the floor area in meters square it is trying to serve?
08-01-2009, 05:52 PM #19
120M² +80m² upstaire.
And the first level is open to the second for 10M²
08-01-2009, 05:54 PM #20
the techincian says the rzq100 was enought !!!
i have buy the 125 and it is too small....
08-01-2009, 06:15 PM #21
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
08-01-2009, 09:27 PM #22
200 square meters, at 120 watts per square meter you will need 24kw and you have about 12.5kw, have you done a heat loss calculation on the place?
09-01-2009, 10:34 AM #23
the technician had done a heat loss calculation and say the rzq100 was enought. With my calculation i thought the 125 maybe could be ok.
Today humidity is 75% and T° -1. I have 22 indoor !!!!
09-01-2009, 11:07 AM #24
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
That is indication that your AC produce insufficient heat for that outdoor conditions. Either you need some backup heating, or you need additional AC for harsh weather conditions, depending on your climate (if that AC is OK, and appears it is).
09-01-2009, 11:56 AM #25
ok thanks.
Cédric
Daikin not working... many problems
By stankovicv in forum Air ConditioningReplies: 26Last Post: 11-12-2010, 09:01 AM -
Daikin, Why do we bother?
By gwilliamson in forum Air ConditioningReplies: 21Last Post: 02-02-2010, 09:38 AM -
Daikin Comp and inverter
By WCC73 in forum Air ConditioningReplies: 5Last Post: 08-11-2008, 08:44 PM -
Getting a price from Daikin....
By monkey spanners in forum Chit Chat & Service StoriesReplies: 4Last Post: 17-08-2008, 09:46 PM -
DAIKIN - Weybridge: How to get a Quote.
By Makeit go Right in forum Air ConditioningReplies: 12Last Post: 25-04-2007, 08:50 PM
