Results 1 to 2 of 2
31-12-2008, 08:28 PM #1
Thermo King SBIII Alarm Code 29???
Hi All,
I have a Thermo King SBIII Max unit, year 1995, 18,000 hours. When I set a target temperature to lets say 26 F, the cooling kicks in for about 2 minutes and then switches to defrost for about 1 minute. It doesn't cool down and just switches between the two. After w fe minutes I am getting alarm code 29. I had this situation a year ago, when it was raining quite a bit. After about a week the problem went away and worked fine until now. Please help.
Also, does anyone have a service manual for the unit. I also want to check the defrost sensors, but I am not sure where they are? How many of them are there?
Thanks,
Paul
31-12-2008, 10:04 PM #2
Re: Thermo King SBIII Alarm Code 29???
Based on the description you have given, I would guess that it is the evaporater differential pressure switch. You say it runs a couple minutes, perhaps soon as the unit calls for high speed operation, the diffential on both sides of the evap change.
Couple things I would check..
Basics.....
- Make sure the evaporater coil fins are clean. no dirt or plastic debris.
- Verify that the return air and discharge stream is not obstructed.
- Verify the air switch wiring, and hoses are connected and in place from the switch all the way to the evap section.
- Finally using a magnehelic gauge test the air switch setting. it should be around 1.0 in
A-Z
Carrier Transicold Container Problem
By Shamel in forum TransportReplies: 39Last Post: 23-01-2012, 11:23 PM -
Thermo King Alarm Code
By sneaquie in forum TransportReplies: 7Last Post: 21-01-2011, 06:27 AM -
Thermo King v? 00 MAX Tc Wiring Diagram
By Chris2005 in forum TransportReplies: 3Last Post: 01-02-2006, 08:01 AM
