    Feb 2004
    scotland
    15
    Aspen Universal Con Pump
    Hi Guys ,
    Fitted one of the above to-day,just a set of mains to it for power but how does it work ? does it sense a temp diff across the two sensor leads ? anybody explain to a thick spark????
    Thanks again,
    Frank McBride.
    Oct 2003
    5,630
    34
    Quote Originally Posted by frankmcbride
    Hi Guys ,
    Thanks again,
    Frank McBride.
    Exactly as you thought. The 2 sensors senses the difference in temperature when the unit starts and will pump some time after the unit shuts down.
    Jan 2003
    East Anglia
    1,160
    Hello Frank,
    Aspen pumps are quite popular over hear. Just one piece of advice if you come accross these in the future. always check the pump head tube (White pipe goes around 180 degree's) These after time begin to go flat where the wheels go round them all the time and therefore looses some of it's pumping ability. New pump head tubes are available from all good stockists at about £5 each and are a piece of cake to fit.
    Raymond
    11,025
    Re: Aspen Universal Con Pump
    Frank, we assume that you have read the instructions so don't call yourself a thick sparky
    Also make sure that you mount the pump the correct way up otherwise the grease comes out of the bearings and the thing shuts down.
    Feb 2004
    scotland
    15
    Thanks for that guys.............. yes i`ve fitted the wee white tubes ,got them through Control Centre, visted site to-day and Daikin indoor unit & pump doing fine. I find every day is a school day learning all the time i`ve got my Corgi Card Industrial & commercial elements & now dabbling in A C & with the help i`m getting from you guys and reading all your postings i`m learning more.
    Frank McBride.
  1. liquid ammonia pump calvitation
    By Kathleen in forum Trouble Shooting
    Last Post: 20-05-2011, 02:18 AM
  2. frostles heat pump
  3. How to make ice with a heat pump
    By Brian_UK in forum Chit Chat & Service Stories
    Last Post: 23-03-2006, 09:09 PM
  4. New pump
    By Peter_1 in forum Air Conditioning
    Last Post: 13-12-2003, 06:19 PM
  5. System Pump Down
    By Brian_UK in forum Technical Speculations
    Last Post: 25-10-2001, 10:39 PM
