Results 1 to 22 of 22
29-12-2008, 08:35 PM #1
Air conditioner tripping on low oil pressure.
The air conditioner having 20 hp semi hermatic compressor, trips on low oil pressure some time.The temperature of the cold room is to be maintain around 6 degree centigrade ,and the atmosheric temperatur of the (Winter)vary from -2 to -15 degree centigrade.
Seeking help.
Thanks,
g.karsandas
29-12-2008, 10:01 PM #2
Re: Air conditioner tripping on low oil pressure.
29-12-2008, 11:42 PM #3
HI Andy,
You can say it is a cold storage.It does have a defrost,it operate once in 24 hours.The defrost timer is kept for 1/2 an hour.
Thanks,
Gkarsandas
30-12-2008, 01:34 AM #4
Is the compressor in a warm room or is it sitting in the cold air?
Without crankcase heaters on it, you might see the same problem... The oil is diluted by liquid refrigerant in the crankcase. Even thought the refrigerant is liquid the oil pump will not generate sufficient pressure to keep the oil safety switch closed.If all else fails, ask for help.
30-12-2008, 01:02 PM #5
30-12-2008, 01:24 PM #6
g.karsandas,
what brand is that low pressure control?
regards,abet
30-12-2008, 01:41 PM #7
31-12-2008, 07:55 PM #8
31-12-2008, 08:40 PM #9
01-01-2009, 03:31 AM #10
Is the oil preasure safety wired last in the control circuit?
Ie thermistor then hp/lp switch then oil preasure switch
01-01-2009, 01:17 PM #11
02-01-2009, 12:07 AM #12
Air conditioner tripping on low oil pressure now are you shore its triping on oil or is the compressor trying to start but gose off on overload and the o.p.s. times out. I had this some time back. or is the o.p.s. one of these setronic where the serscer sits in the oil they need to be remved and cleaned.
02-01-2009, 02:50 PM #13
04-01-2009, 11:16 AM #14
gedday k.G, is this a new system that's had the oil problem since it was installed or is it an old system that has run fine till recently?
Do you have some sort of head pressure control on it?
What's your operating head, suction and oil pressure?
What type of compressor are we looking at?
What's the temperature of the suction line at the compressor?
If you can answer all these questions it may make it easier to work out what is causing your problem.
Cheers,
Slatts
04-01-2009, 11:25 AM #15
Almost forgot, What refrigerant is in the system?
What type of compressor is it?
07-01-2009, 02:26 AM #16
08-01-2009, 08:48 AM #17
11-01-2009, 07:38 PM #18
sounds to me like the system is not getting enough defrost, if the room is to maintain +6c (chiller) it should have 6 defrost in a 24hr period! i take it oil level is ok/filter ok? has system got oil seperator on it?
14-01-2009, 05:29 AM #19
I ran into this type problem on a freezer that had a condensing unit on the roof, discovered a faulty OFS (Johnson Contrls) last in cct to the comp contactor.
had to Re&Re it....
The OFS first took a pounding from controlling 208V cicuit, but what I noticed is that when the unit got close to satisfying some liquid would make it back past the Accumulator and washout the oil going through the oil pump. the OFS then would trip out after a 90 second time out.
I ended up checking the superheat to the comp and noticed that it was to low @ around 5º, I increased it to 18º by (patiently) adjusting the TXV. the system works fantastic now....
14-01-2009, 09:53 AM #20
Gedday Mark. The number of defrosts per day is related to the duty of the room (how heavily the room is used eg; the number of times the door is opened), ambient conditions (Temperature and humidity),type of stock in the room and coil TD.
On a little used room, full of cans of drink installed in a dry, air conditioned room, you may well get away with 1 defrost per day.
Horses for courses mate.
Enthalpy, I take it you haven't been doing this long?
Sounds like the oil safety was just doing what it was supposed to do.
You need to check the SH at the evaporator.
Set it up at 4 to 6K at the TX valve bulb then check your SH at the compressor.
Since the system has a suction accumulator you should have heaps of SH at the suction service valve once the TX valve is set up properly.
If you just shut the valve down to get some SH at the compressor you could still be either flooding the coil and suction line, there by increasing the suction pressure and wasting capacity or you could end up starving the evaporator and loose capacity that way.
Either way we seem to have misplaced the OP.
15-01-2009, 02:45 AM #21
Either way we seem to have misplaced the OP.[/QUOTE]
nope in my case the OFS was faulty........
15-01-2009, 08:38 AM #22
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM -
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM -
Building a wine cabinet
