Results 1 to 9 of 9
Thread: Daikin FTD35F R1T Air Thermistor
27-12-2008, 07:48 AM #1
Does anyone have the specifications for RT1 air thermistor in the indoor unit?
Does anyone have any modification diagrams to shift the thermistor temperature range? To basically trick the unit in thinking it is warmer than what it actually is, or vice versa.
27-12-2008, 10:28 PM #2
Re: Daikin FTD35F R1T Air Thermistor
would like to use the remote control to view the air thermistor temperture.
I can access the fault diagnostics no problem etc. (Temp Up, Temp Down, Mode).
How can I access the thermistor readings?
27-12-2008, 11:18 PM #3
Press and hold the test button until the figure 10 shows.
Release button and press again, holding until the figure 40 shows. Release button
Press temperature up to display figure 41.
Second display, to left of 41 should show a code 00 with a figure underneath, say 21; that is the thermistor in the remote controller.
Press the button to the left of the temperature buttons to change the code to 01 which is the thermistor in the air return to the unit.
Repeat the exercise to code 02 and you will see the coil temperature.
Press test to exit.
edit: Email sent.Last edited by Brian_UK; 27-12-2008 at 11:39 PM.
27-12-2008, 11:22 PM #4
Brian, thanks, although the remote does not have a test button.
28-12-2008, 06:31 AM #5
That's only because Brian gave you the info on a controller whcih can't be fitted to your system..
However as you're in AU try this guy on the first poast he has the same unit and the service manual etc
http://forum.auswine.com.au/viewtopi...a621b7c0ec7dba
28-12-2008, 06:53 AM #6
I did contact him, but he did not know how to monitor the thermistors from the remote.
28-12-2008, 09:11 PM #7
28-12-2008, 10:54 PM #8
Yer Ive got those specs now.
29-12-2008, 12:16 PM #9
Daikin 4MX80HV1NB probs...
By eggs in forum Air ConditioningReplies: 14Last Post: 21-07-2011, 07:48 PM -
Daikin not working... many problems
By stankovicv in forum Air ConditioningReplies: 26Last Post: 11-12-2010, 09:01 AM -
Daikin Comp and inverter
By WCC73 in forum Air ConditioningReplies: 5Last Post: 08-11-2008, 08:44 PM -
PTC & NTC Probes.
By Testech in forum ElectricalReplies: 17Last Post: 06-06-2008, 10:01 PM -
Daikin 1.5HP Cooling Only Non-Inverter (model FTD35F) compressor on/off
By Cellar Dweller in forum FundamentalsReplies: 12Last Post: 16-01-2008, 01:32 AM
