Results 1 to 1 of 1
26-12-2008, 01:29 AM #1
R22 pump recirculation system with 2 Evaporating temperature
Hello everybody,
The IQF is -40 C ET, and the storage room is -31C ET with -25C room temperature. They share one liquid and wet suctoin line. Could I just let them share one same ET -40C. I think this will not cause any problems. The room doesn't have any humidity requirements. Do I need to add one back pressure valve in the -31C evaporators' outlet and is practical to add the suction pressure valve in the wet return line?
Thanks in advance!!
JerrycoolLast edited by JERRYCOOL; 26-12-2008 at 01:36 AM.
LG heat pump problem
By back2space in forum Heat PumpsReplies: 132Last Post: 01-02-2009, 11:23 PM -
Thermo King OptiSet
By REEFER-TEK in forum TransportReplies: 4Last Post: 06-12-2007, 07:23 PM -
Evaporating / condensing temperatures
By Contactor in forum FundamentalsReplies: 46Last Post: 22-07-2007, 11:19 PM -
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 03:42 PM -
System Pump Down
By Brian_UK in forum Technical SpeculationsReplies: 16Last Post: 25-10-2001, 10:39 PM
