Results 1 to 1 of 1
    Jul 2005
    SOMEWHERE IN THE PLANET
    67
    R22 pump recirculation system with 2 Evaporating temperature
    Hello everybody,
    The IQF is -40 C ET, and the storage room is -31C ET with -25C room temperature. They share one liquid and wet suctoin line. Could I just let them share one same ET -40C. I think this will not cause any problems. The room doesn't have any humidity requirements. Do I need to add one back pressure valve in the -31C evaporators' outlet and is practical to add the suction pressure valve in the wet return line?
    Thanks in advance!!
    Jerrycool
  1. LG heat pump problem
    By back2space in forum Heat Pumps
    Last Post: 01-02-2009, 11:23 PM
  2. Thermo King OptiSet
    By REEFER-TEK in forum Transport
    Last Post: 06-12-2007, 07:23 PM
  3. Evaporating / condensing temperatures
    By Contactor in forum Fundamentals
    Last Post: 22-07-2007, 11:19 PM
  4. Refrigeration system proposal; comments please.
    Last Post: 01-01-2003, 03:42 PM
  5. System Pump Down
    By Brian_UK in forum Technical Speculations
    Last Post: 25-10-2001, 10:39 PM
