Thread: Applications of heat pipes
23-12-2008, 11:22 AM #1
Hello, can you share with me any example applications of heat pipes. Maybe you now interestnig aplications (heat bridgest). Thanks for your help.
23-12-2008, 12:04 PM #2
Re: Applications of heat pipes
one application is enhanced dehumidification
heat pipes wrap around a cooling coil, they pre-cool the entering air, this allows the cooling coil to pull out more moisture, then the same heat removed precooling gets transferred back to the air leaving the coil as reheat
another use is in heat recovery ventialtion, they transfer heat between two air streams.
A more famous use is to keep the earth surrounding the alaska pipe line footings frozen so there is no heaving up and down every time the seasons changeTake the V out of HVAC and you are left with a HAC job
23-12-2008, 12:07 PM #3
Evacuated solar heat pipes used to heat water. Airconditioning for fresh air.
23-12-2008, 09:55 PM #4
Compressor crank case heating
24-12-2008, 08:10 AM #5
Contactor, could you share with me any materials about compressor crank case heating by heat pipe. Maybe you have any diagram how does it work or you know any www links. Thank you.
18-01-2009, 06:18 AM #6
How about on heat recovery?
Capacity control
By sparrow in forum TrainingReplies: 44Last Post: 18-01-2010, 07:49 PM -
System sizing for heat and manual J
By Larry2 in forum Heat PumpsReplies: 5Last Post: 25-06-2008, 10:58 AM -
frostles heat pump
Passive cooling of CPU using heat pipes
By momo in forum CPU OverclockersReplies: 3Last Post: 23-03-2008, 07:59 PM
