    rabix's Avatar
    rabix Guest
    Applications of heat pipes
    Hello, can you share with me any example applications of heat pipes. Maybe you now interestnig aplications (heat bridgest). Thanks for your help.
    Jun 2006
    British West Indies
    543
    Re: Applications of heat pipes
    one application is enhanced dehumidification
    heat pipes wrap around a cooling coil, they pre-cool the entering air, this allows the cooling coil to pull out more moisture, then the same heat removed precooling gets transferred back to the air leaving the coil as reheat
    another use is in heat recovery ventialtion, they transfer heat between two air streams.
    A more famous use is to keep the earth surrounding the alaska pipe line footings frozen so there is no heaving up and down every time the seasons change
    Take the V out of HVAC and you are left with a HAC job
    Aug 2007
    Sydney
    1,083
    23
    Evacuated solar heat pipes used to heat water. Airconditioning for fresh air.
    Scotland
    327
    Compressor crank case heating
    rabix's Avatar
    rabix Guest
    Contactor, could you share with me any materials about compressor crank case heating by heat pipe. Maybe you have any diagram how does it work or you know any www links. Thank you.
    Dec 2008
    China
    87
    How about on heat recovery?
  1. Capacity control
    By sparrow in forum Training
    Last Post: 18-01-2010, 07:49 PM
  2. Replies: 5
    Last Post: 14-09-2009, 07:33 AM
  3. System sizing for heat and manual J
    By Larry2 in forum Heat Pumps
    Last Post: 25-06-2008, 10:58 AM
  4. frostles heat pump
  5. Passive cooling of CPU using heat pipes
    By momo in forum CPU Overclockers
    Last Post: 23-03-2008, 07:59 PM
