Thread: Samsung RL33SBSW Problem
22-12-2008, 10:14 PM #1
Hi Guys and Girls,
I've got a problem with my fridge/freezer in that it just locks out, i.e. the indicator neons at the top front stay lit, but the evap fan is at a standstill and the compressor is off...It happily restarts if I switch it off and on at the mains only to lock out again several hours later. I suspect its something to do with the defrost cycle i.e. not terminating the defrost at the evaporator probe, but surely there is a max' time out.
I normally work on supermarket equipment so forgive my ignorance, would anyone know if the Samsung sensors types are PTC, NTC etc...
Any help or suggestions gratefully received.
Cheers RNINE
22-12-2008, 10:58 PM #2
Re: Samsung RL33SBSW Problem
airkool@hotmail.co.uk
will email u all tech u need
24-01-2009, 06:06 PM #3
Yep defrost cycle it is, first check the thermal fuse, then the heater.
28-01-2009, 01:55 AM #4
aha - I have exactly the same problem !!
where is the thermal fuse ??
and what reading should the heaters be roughly ? (one I measured was about 10k which is seeming quite wrong now I think about it)
many thanks
O.
Possible Samsung Problem
By airefresco in forum Air ConditioningReplies: 8Last Post: 28-07-2008, 07:50 PM
