Results 1 to 10 of 10
    Dec 2008
    arizona
    Post Heat pump knocks
    Periodically, my heat pump starts knocking and sounds like a fan blade hitting on a flang. Not so. Fan running clear and moving air. Have removed cover and fan blade moving freely. But about once every two weeks it sounds like the whole thing is coming apart.
    Symptoms. Small house (Casitas Approx 800 sq ft) with external heat pump. In Tucson AZ. Pump is a Rudd maybe 15 years old. In heat cycle - Knocking is consistent in frequency and volume. (Like a revolving fan blade). Knock knock. Turned system off. 30 minutes later turned on. No noise. Huh?
    SWAG - replace or repair? Possible cause and cost??
    11,024
    Re: Heat pump knocks
    Is there any frost or ice visible when you get this sound?
    It could be the fan blade touching the ice. If so then you need to check that the defrost cycle is performing properly.
    Dec 2008
    arizona
    Thanks Brian. Checked - No ice. Knocking coming from lower part of outside unit - and it is loud. ttfn
    May 2008
    66
    802
    is it a water-air pump??
    could there be air in the pipes??
    could there be ice or nearly ice in the pipes???
    if it is refrig al around,could it be a valve that is opening and closing to soon and to fast??
    just some thoughts,
    Ice
    Ice
    Dec 2008
    arizona
    Quote Originally Posted by icecube51 View Post
    just some thoughts,
    Ice
    Ice
    Not sure of answers. It is an external unit with lines to house (similar to an A/C unit). Approximately a 3 foot cube. Compressor or some unit below and a fan on top. When knocking was there, fan was running free and clear. No restrictions. Knocking seemed to come from below and was consistently repeated - like a blade hitting, but no visible sign of moving part. Huh? Thanks for the input.
    May 2008
    66
    802
    hopefully it is not the compressor that is nocking. did you check the refrig?? high and low presure ?? when the nocking ocure,do you see ice somewhere ??
    what is the brands name and type of the unit.there must be a display somewhere.
    Ice
    May 2006
    Isle of Wight, Uk
    47
    424
    Is the fan blade tight - does the nut need doing up a bit ?
    Sometimes they get loose over the years and when the fan pulses in it knocks slightly.
    Andy
    Dec 2008
    arizona
    Fan blade is tight and at different speed than knocking.
    Dec 2008
    arizona
    Ice
    Unit is a Rudd Achiever 9 Hig Efficiency heat pump. Probably about 5 years old. Knocking seems to occur after unit has been running for some time. If you turn the unit off, allow it to set for 15 minutes and turn it on again, Voila. No knocking. Appreciate your help.
    Dec 2008
    arizona
    Quote Originally Posted by Jamieheatpump View Post
    oops. Unit is a High efficiency and is about 15 years old.
  1. Capacity control
    By sparrow in forum Training
    Last Post: 18-01-2010, 07:49 PM
  2. DIY heat pump 12kW
    By kimusabi in forum Fundamentals
    Last Post: 17-10-2009, 07:50 PM
  3. frostles heat pump
  4. Will this heat pump work?
    By goodguy in forum Heat Pumps
    Last Post: 08-03-2008, 04:14 PM
  5. Domestic VRF heat pump?
    By electronicsuk in forum Heat Pumps
    Last Post: 30-10-2007, 07:53 AM
Tags for this Thread
