Thread: Husky Spares uk
22-12-2008, 09:59 AM #1
Husky Spares uk
I am trying to track down where i can get husky spares,I only need a light fitting for a DS5F,Havent been to site so dont know if i can pic one up from a electrical wholsalers,Hope someone can help..
22-12-2008, 01:05 PM #2
23-12-2008, 10:56 AM #3
Re: Husky Spares uk
Thanks buddy.
29-04-2010, 12:32 PM #4
Re: Husky Spares uk
in fact they have now subbed out spares etc to "Husky technical Services" in ireland
huskytechnicalservices.com
Tel. 07000 4733744 or 02830 825455
HTH - Richard
05-05-2010, 12:47 PM #5
Re: Husky Spares uk
Dear Sir/Madam,
I am having a problem with a Husky Frilixa,Marao 1.5,dairy cabinet comming down to low in temperature & not cutting out,is this due to air probe or possibly pcb? Thank You
05-05-2010, 01:38 PM #6
05-05-2010, 02:08 PM #7
Re: Husky Spares uk
If it has digital thermostat and it is showing too cold on this but is still cooling, most likely it is either set wrong or the controler is faulty.
If it is reading the correct temp on the digital controler but too cold on another thermometer then it is most likely the probe or the probe offset has been set wrong.
It could be many other things such as a leaky solenoid, wiring fault, etc etc
In future, you will most likely get more responses to technical problems if you start a new thread for them instead of joining an existing one.
Husky C-800 Icemaker
By Radlam in forum CommercialReplies: 3Last Post: 23-07-2008, 01:39 PM -
LG Spares
By gazcull in forum Air ConditioningReplies: 3Last Post: 03-06-2008, 10:01 AM -
Spares
By Fridge magnate in forum CommercialReplies: 1Last Post: 20-02-2007, 08:00 PM -
Carrier spares
By daddymac in forum Air ConditioningReplies: 6Last Post: 21-03-2006, 08:54 AM
