Thread: CPU Evaporators
    Dec 2008
    Lebanon, PA
    CPU Evaporators
    After seeing some of these stepped and spiral designs, I was wondering who is producing these? I would like to get one or two to try and test. Seems you use very small evaporators though considering the heat load sometimes you are looking at. 1.5" diameter and 1 to 2" tall? Rather tiny! Is there something to prevent 2.5" diameter and 4" tall? Or even bigger?
    Unless your using an autocascade and have designed for back flow (in which case this helps which can be rather nice if it's designed for, or a nuisance at low loads if you forgot (haha)) it seems your doing nothing more then wasting even more power...
    Teyber's Avatar
    Teyber Guest
    Re: CPU Evaporators
    Quote Originally Posted by Reflexive View Post
    hey!
    (edit- good rule here! i can't post url's until i have 15 posts. ill post it then, but that must help a lot with spam!)
    there is some of my work. The evaps are small because of.... Cost! if you wanted a 3" evaporator it would cost in the hundreds of dollars 1.5" covers the core and my evaps are only ~ 1" tall.
    The "big" evap i made is made from 1 5/8" copper and is ~ 2" or maybe 1.75" if i remember. I want to try a 2.25" evap soon though my friend
    Cheers!
    70
    10,627
    52
    Re: CPU Evaporators
    Hi Teyber and welcome.
    Although you can't yet post a URL you can type it long-hand if you want and we will cut and paste/modify it ourselves....
    http : // w w w dot google com / show test.etc
    May 2008
    malaysia
    34
    82
    11
    Re: CPU Evaporators
    can somebody show me the cpu evaporators in picture...pls hongfain@hotmail.com
    thanks a lot.....
  1. 1 Tev 2 Evaporators
    By Renato RR in forum Technical Discussions
    Last Post: 18-11-2009, 02:58 PM
  2. Flooded & Pump Evaporators
    By MrReds in forum Fundamentals
    Last Post: 24-01-2007, 10:11 PM
  3. Flooded & Pump Evaporators
    Last Post: 24-01-2007, 06:29 PM
  4. Liquid line for multi evaporators
    By Kevin Yeo in forum Supermarket Refrigeration
    Last Post: 29-12-2005, 02:29 PM
  5. Evaporators: Stainless Steel or Galvanized S.
    By Friobernal in forum Technical Discussions
    Last Post: 28-10-2002, 09:04 PM
