Results 1 to 2 of 2
Thread: Booster compressor.
17-12-2008, 09:47 PM #1
Booster compressor.
Hello,
Seeking help to know the principal and type of of Booster compressors in refrigeration system and their applications.
g.karsandas
17-12-2008, 10:34 PM #2
Re: Booster compressor.
Welcome to the RE forums.
A booster compressor is similar to any other compressor in basic function. It compresses the refrigerant from a lower pressure up to a higher pressure.
When you hear the term booster compressor this means that compressor is part of a two-stage compression system (typically used for low temperatures). This is the simple version of what a booster compressor does: It pulls in low temperature, low pressure refrigerant and compresses the refrigerant up to a somewhat higher pressure. This pressure is usually called the intermediate pressure or interstage pressure.
At this intermediate pressure another compressor (called the high stage compressor) pulls the refrigerant from this interstage pressure and compresses the gas up to the condensing pressure (or discharge pressure).
A booster compressor can have capacity control similar to a high stage compressor. However, some boosters may not have any capacity control.
Some types of common industrial booster compressors are: screw, reciprocating, or rotary vane.
If you have some other questions related to this, feel free to post them in this thread you started.If all else fails, ask for help.
Booster compressor?
By zolimer in forum NH3Replies: 23Last Post: 01-10-2008, 05:31 AM -
booster compressor
By matt watson in forum NH3Replies: 10Last Post: 10-06-2008, 11:12 AM -
SL/SB-400 Pump Down Procedures
By absolute-zero in forum TransportReplies: 1Last Post: 29-01-2008, 09:27 PM -
Different between compressor MYCOM single stage and compressor booster
By thien nhat in forum CommercialReplies: 7Last Post: 13-12-2007, 06:31 PM -
Compressor pumping efficiency
By shogun7 in forum FundamentalsReplies: 0Last Post: 25-02-2004, 10:50 PM
