    Graham Eady's Avatar
    Graham Eady Guest
    Help with energy calcs
    I am using an 'air load' calculator which gives me a total cooling load in kBtu for an installation based on the cfm for different locations around the US.
    The figure that I get is the cooling required to bring the air temp down to the required set point but I want to be able to convert this figure to the required electrical load for the whole cooling plant.
    What I am looking for are some 'rules of thumb' for coming up with the calculation.
    The air supply that is being cooled will be provided via an AHU ( air handling unit ) and the systems are 'full fresh air' ( no re-circulated air ) and I assume that it will have a dx coil or a cooling coil operating on chilled water.
    I have looked at packaged chillers on the web and have a good idea of the general power input to cooling load output --
    what I need now is an idea of the efficiency of a cooling coil and the associated pipe work.
    I have a methodology for different heating systems e.g. if we have a gas fired boiler providing low pressure hot water to a coil in an AHU I assume an efficiency of 80% for the boiler and an efficiency of 66% for the heat tranfer to the air ( includes pipe heat losses and heat tranfer in the coil to the air )
    Can I assume a similar 66% for a chilled water circuit through a cooling coil ?
    If we are using a dx coil in the air stream -- what is the efficiency of the cooling ?
    As you have probably guessed, am an electrical engineer not a refridgeration engineer.
    HELP
    Split Croatia
    57
    6,151
    36
    Re: Help with energy calcs
    Efficiency of chiller is about 250-300%!
    Graham Eady Guest
    Thanks for the reply.
    Do you have any figures for the efficiency of the application -- for example the chiller will produce chilled water according to it's efficiency but then this water is passed through a coil in an AHU -- how much is typically lost in the pipework and efficiency of the cooling transfered to the air passing through the AHU -- in other words the 'application efficiency'
    Mar 2008
    68
    250
    For a typical chilled water A/C application you would expect to gain approx. 1c from the chiller to the AHU inlet & another 1c on the way back. So for a chiller leaving water temp of 7c it would arrive at the AHU at 8c + the AHU DT (normally 5c) sub total 13c +1c for the return & back to the chiller at 14c or so.
    Pipe run lengths, insulation, type of coil in AHU and ambient temps will determine actual overall system efficiency. Pumps might also have a small effect.
    A Dx system will be more efficient than a chilled water but harder to control to match fluctuations in fresh air.
    If in doubt read the instructions. If still in doubt follow them.
  1. Helpful information
    By chemi-cool in forum Tools and Calculators
    Last Post: 30-10-2010, 07:00 PM
  2. Energy Conservation
    By US Iceman in forum Technical Speculations
    Last Post: 20-07-2010, 10:52 AM
  3. Thermal Efficiency of Refrigeration System
    By hussain316 in forum Refrigeration Books
    Last Post: 31-07-2007, 08:59 PM
  4. A question about energy efficiency rating in Europe
    By pcdata76 in forum Fundamentals
    Last Post: 22-05-2006, 10:17 AM
