    Oct 2008
    uk
    54
    5
    Hitachi FSN1 3 pipe vrf r410a
    Hi all,
    does anyone out there have the technical manual for an hitachi ras 10 fsn1e 3 pipe vrf. I need to change the discharge pressure transducer tomorrow. I have found the problem with the system just need to know if there is a schrader valve fitted at the sensor and if I can simply unscrew it and replace without spending hours on gas recovery etc. Any help is much appreciated.
    Mar 2007
    Warwickshire UK
    723
    21
    Re: Hitachi FSN1 3 pipe vrf r410a
    The last Hitachi one I changed was on a schreader but they tend to change the specification from time to time so you can never be absolutely sure.
    The safety HP switch is brazed in as I recall. But the pressure sensors are on schreader so can be unscrewed & replaced easily.
    Oct 2008
    uk
    54
    5
    Thanks a lot. Was there last week I remember seeing the hp switches brazed on as you say but was in a rush to go after finding the problem so did not take a lot of notice how it was attached. Got the new sensor now but wasn`t looking forward to pulling the gas out cause I`ve got the slowest recovery machine in the world. Thanks again.
    Apr 2006
    stafford
    42
    974
    Quote Originally Posted by s.wallbank View Post
    Hi all,
    log onto
    http://www.hitachiaircon.com/argws/l...n=loginForward
    register at
    http://www.hitachiaircon.com/argws/U...d=RegisterUser
    Paul
    "KEEP IT COOL"
  1. Measurement of pipe lengths
    By batfink in forum Technical Discussions
    Last Post: 23-09-2008, 09:50 PM
  2. Burst Pipe caused by Abrasion. (aka Only on a Friday)
    By Grizzly in forum Chit Chat & Service Stories
    Last Post: 19-09-2008, 06:59 PM
  3. Mitsubishi PUHZ-RP200YHA Pipe Sizes
    By gwilliamson in forum Air Conditioning
    Last Post: 14-05-2008, 09:43 PM
  4. Copper pipe for Mitsubishi R410a Models
    By Chris2005 in forum Air Conditioning
    Last Post: 26-01-2008, 12:30 AM
  5. Pipe sizes
    By benncool in forum Chit Chat & Service Stories
    Last Post: 08-07-2003, 10:58 PM
