    fredboer's Avatar
    fredboer Guest
    Biter Compressor HP, and Application
    Hi could you help with telling the horsepower of a Bitzer Semi hermatic Condensing Base from the model number. R-CN-33-2HC1.2, R-CN-33-2HC1.2Y, and their application HT or LT
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Biter Compressor HP, and Application
    It's the smallest condensing unit produced by Bitzer. It's a 1HP, 1.2kW approx capacity, 6.5m3/h, MT and LT unit.
    2HC1.2 is the compressor model.
    The Y just stands for POE oil.
  1. Remote air cooled application
    By David T in forum Tools and Calculators
    Last Post: 04-06-2010, 02:02 PM
  2. size capillary for any application & refrigerant
    By benijoseph in forum Technical Speculations
    Last Post: 07-06-2009, 10:00 AM
  3. HBP compressor used in LBP application
    By Beltdrive in forum Fundamentals
    Last Post: 19-08-2008, 10:34 AM
  4. industrial heat pump application
    By Lc_shi in forum Heat Pumps
    Last Post: 24-08-2006, 02:48 PM
  5. Low back pressure compressor application
    By Abe in forum Technical Discussions
    Last Post: 31-07-2001, 11:43 PM
