    gleeary's Avatar
    gleeary Guest
    nitrogen purging
    hi
    can any guide me
    i am starting vrf shortly what is the proceedure for nitrogen purging
    Nov 2007
    Scotland
    49
    Re: nitrogen purging
    You shall have to blow a small amount of OFN through the pipe work when you are brazing roughly 5 psi. Connect a hose to your regulator and put it into the end of the pipe you are brazing.
    Oct 2006
    1,843
    21
    Quote Originally Posted by gleeary View Post
    hi
    can any guide me
    Hi mate.
    Its not specific to VRF / VRV. You should purge oxigen free nitrogen (OFN) through all fridge pipework that is being brazed. It is good practice and stops the build up of oxides (carbon, sooty deposits) forming on the inside of the pipe.
    taz.
    Jul 2008
    taguig city
    36
    gleary,
    standard practice on copper pipe brazing is to have a flow of 10 psi dry nitrogen on the pipe so not to oxidize it.
    regards,
    3,856
    I've got a flow meter for about fifteen notes from a welding supplies shop/Boc agent which is intended for co2 when mig welding, works a treat with ofn, also got a cheap low pressure regulator to go with it, just set the flow at X litres a minute to suit the size of pipe, bigger pipe-more flow. Saves ofn and you actually know its flowing rather than just pressurising the pipe as the little bead rises in the tube with the flow. Will try and post some pictures tomorrow. Looks professional too imo.
    Jon
    11,025
    Strange that when people start installing VRV/VRF they feel that they should start using OFN.
    Is it them big scary pipes
  1. brazing under nitrogen
    By cool#9 in forum Air Conditioning
    Last Post: 24-10-2010, 08:30 AM
  2. Nitrogen purging?
    By monkey spanners in forum Tools and Calculators
    Last Post: 10-06-2007, 09:47 PM
  3. purging air from condenser
    By faryuki in forum NH3
    Last Post: 23-04-2007, 08:03 AM
  4. Nitrogen freezer
    By Peter_1 in forum Industrial
    Last Post: 05-10-2005, 05:04 PM
  5. nitrogen purging
    By freezy in forum Fundamentals
    Last Post: 30-08-2005, 10:34 AM
