Results 1 to 8 of 8
Thread: Coldrooms overflow discharge
08-12-2008, 02:06 PM #1
Custom built cooler and freezer in restaurant kitchen.
Does anyone know if there is legislation regarding how/where is the proper way to discharge the overflow please? Using a bucket is not an option.
Any feedback will be appreciated.
08-12-2008, 11:02 PM #2
Re: Coldrooms overflow discharge
Hi Jeffrey and welcome to the forum.
What sort of 'overflow' are you referring to?
If it is the condensate or defrost drain from the evaporator coils then, like most drains, it should be connected to one of the normal building drains so that it discharges down the sewer. It must include a trap of course.Brian - Newton Abbot, Devon, UK
26-12-2008, 09:13 PM #3
Hi Brian UK. Thank you for your reply.
Much obliged.
27-12-2008, 03:10 PM #4
May I suggest that the above is "good and best practise" Brian.
Although not Mandatory as far as I am aware?
Otherwise most of the Installs that I come across would fall fowl of this!
Can anyone confirm as to what Brian suggests?
Cheers Grizzly
(not a criticism Brian just questioning whether so many installs can be wrong!)
27-12-2008, 06:57 PM #5
Hello Grizzly
In N.Ireland this would be mandatory under building control.
If a building control officer was checking a new job or renovations where plans had been submitted, he could turn the job down until traps had been fitted prior to where a drain enters the foul drain.
Kind Regards AndyIf you can't fix it leave it that no one else will:rolleyes:
27-12-2008, 11:54 PM #6
Sorry Guys,
I may have used the wrong terminology.
I understand the need for proper condensate or defrost drain lines in a food environment.
With their requisite vapour traps.
As Brian stated, my question is is it still a requirement when talking about a condensate line on say a split system?
Meaning at what stage if any does it no longer become a requirement to terminate to a drain?
Thanks Grizzly
28-12-2008, 12:04 AM #7
Interesting question Grizzly.
I was only looking at the kitchen environment and providing an alternative to the bucket collection method.
I think that any other type of drainage, non-food, can be discharged where ever you like, within Codes of course. But, if connecting to a drain then a trap is always useful.Brian - Newton Abbot, Devon, UK
28-12-2008, 10:03 AM #8
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Traps are there to prevent sewage or waste water main drain pipe smell to go to conditioned space thru condensate drainage pipes.
But what with hygiene when you drain your fresh meat cooler condensate thru sewage drain even with trap fitted.
Is there any regulations about that in your countries? And what is practice?
Carrier 23xl chiller-Low discharge superheat alarms
By Bradysmill in forum Trouble ShootingReplies: 7Last Post: 25-04-2010, 07:43 PM -
Screw discharge cooling
By Volnei in forum Industrial CompressorsReplies: 13Last Post: 05-11-2008, 09:24 AM -
Interesting Problem
By NH3LVR in forum Industrial CompressorsReplies: 13Last Post: 12-08-2006, 10:27 PM -
Exploded discharge line
By Peter_1 in forum IndustrialReplies: 1Last Post: 05-05-2004, 09:47 PM -
I need to build two coldrooms
By alpha in forum Technical DiscussionsReplies: 4Last Post: 14-10-2002, 01:31 AM
