Results 1 to 11 of 11
Thread: a simple one
07-12-2008, 08:59 AM #1
a simple one
went to service some split wall mount units service went well they were cheapy b&q ones with no valves
or test points any where service went well apart from1 had a test point on the entrance to the outside unit it was a standard 407a the valve had an allen key at the side to front seat etc but no matter what i did the test point still had pressure the is this normal
07-12-2008, 04:14 PM #2
Re: a simple one
first of all..407a ??? if the unit had refrig ,it always gone have presure. did you check youre gauges ?? is the pin not to far inwards ?? is it pussing the shraeder open ??
Ice
07-12-2008, 06:01 PM #3
Re: a simple one
gauges are fine hoses fine it was every time i tried to screw the hose on i had vapour escaping is this usual or can you isolate like a normal service valve
07-12-2008, 08:06 PM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: a simple one
That is normal!
You could isolate it with quick coupler fitings!
07-12-2008, 11:45 PM #5
Re: a simple one
Gee, you frighten me, have you not connected guages to a system before ?
08-12-2008, 12:17 PM #6
Re: a simple one
yes several times but never had vapour pissing out before as i saked is this normal
08-12-2008, 07:17 PM #7
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: a simple one
Ignore, bad joke!
08-12-2008, 10:28 PM #8
Re: a simple one
Please, insert end points in your lines and capital letters at the beginning of a new one because I barely can read you message.
Like you describe, they're all made this way, so there's nothing special about it.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
09-12-2008, 06:50 PM #9
Re: a simple one
maybe look if the pin on your gauges is not to far out,the one that pusses the shreader in, so when you loosen up there comes to much vapor out the connection.
Ice
09-12-2008, 07:25 PM #10
Re: a simple one
ok thaks guys
16-12-2008, 10:48 AM #11
Re: a simple one
from what u describe it sounds like the schreader valve on the condensing unit is leaking. if both lines have allen key shut-offs the system could be pumped down to allow replacement of the schreader valve. After replacement the charge should be checked
Simple Question.....Simple Answer?
By Daddy Cool in forum FundamentalsReplies: 10Last Post: 20-01-2011, 04:36 PM -
A simple question
By jflebeuf in forum Supermarket RefrigerationReplies: 2Last Post: 17-11-2008, 04:07 PM -
Keep It Simple "KIS"
By REEFER-TEK in forum Chit Chat & Service StoriesReplies: 9Last Post: 01-12-2007, 09:40 PM -
simple....
By koolio in forum Technical DiscussionsReplies: 5Last Post: 11-09-2007, 12:02 PM -
Making a simple water cooled condenser
By The MG Pony in forum FundamentalsReplies: 19Last Post: 01-08-2007, 11:02 AM
