Thread: leak fix
03-12-2008, 10:28 PM #1
leak fix
hi my local nrs supplier was trying to sell me some leak repair in a can i was just wondering if anyone has tryed it and if so how did it work good
03-12-2008, 10:36 PM #2
Re: leak fix
If it can fix a leak then it can fix a TXV
04-12-2008, 03:45 AM #3
Re: leak fix
I have never tried that, but I did try a magic spray from my supplier that was supposed to clean condensor coils, without blowing them out with water or air. A customer of mine insisted on using this product himself...it was like "Easy-Off" oven cleaner. It made dirt and grease etc, dissolve into a mushy sludge, that ran down the coil and hardened at the bottom like cement. I ended up changing a bunch of coils that were plugged so full of this stuff that I couldnt get them clean.
So I say, bring on the magic sprays, they will make us rich in the long run...if we live through the environmental damage.
04-12-2008, 02:59 PM #4
Re: leak fix
seen it, sold it, never used it.. The only thing that should be in a sealed refrigeration circuit should be refrigerant and oil.. If the OEM's thought that stop leak was a good idea they would market it themselves.
04-12-2008, 06:05 PM #5
Re: leak fix
Never introduce any chemical other then specified by the manufactures in the system.
Leak detectors
By Temprite in forum Tools and CalculatorsReplies: 54Last Post: 18-08-2010, 04:15 PM -
Evasive gas leak
By Feeze in forum Technical DiscussionsReplies: 24Last Post: 18-08-2008, 07:22 AM -
temporary leak fix ? / adding refrigerant.
By medicRRR in forum Technical SpeculationsReplies: 7Last Post: 21-06-2008, 11:37 PM -
Gas Leak!
By Chunk in forum Chit Chat & Service StoriesReplies: 18Last Post: 31-03-2008, 06:48 PM -
Help!!! Shell and Tube Evap Leak
By tommy Gun in forum Trouble ShootingReplies: 7Last Post: 22-07-2007, 12:45 PM
