Results 1 to 8 of 8
    Feb 2004
    scotland
    15
    Lennox outdoor unit
    Hi guys ,
    removed cover from outdoor unit ,compressor not running,fan spinning ok,contactor not energised traced wiring, the neutral for the 240v coil is non exsisting it goes through some kind of switch on the suc line................ are these switches valves removable?the unit looks very old are they beyond repair? are spares easy to get ? any help for an old spark ???
    Cheers Frank Mc Bride.
    shogun7's Avatar
    shogun7 Guest
    Frank,
    the sw, on the suction line could be a low pressure cut out to protect the compressor if the system looses it's gas charge. If it's a 3 phase system then from that control you should have a wire to that goes to the compressor motor starter coil and the condenser fan contactor coil (parallel) This is very unuasual it may indicate a bad compressor or out of gas so it was disconnected.
    Roger
    Jan 2003
    East Anglia
    1,160
    Yes It Probably is a LPCO Switch. We have quite a few of these units still working out this way & they are all S***
    Raymond
    Feb 2004
    scotland
    15
    Thanks guys,it`s a single phase job,i`ll have another go at it tomorrow if the bloody rain stays off...............
    11,025
    Re: Lennox outdoor unit
    Originally posted by frankmcbride
    (A) the unit looks very old are they beyond repair?
    (B) are spares easy to get ?
    (A) Yes, chuck it
    (B) Don't waste time on it.
    Jan 2003
    East Anglia
    1,160
    Hello Frank,
    Got to aggree with Brian on this one especially if it's one of them S***ty units that has gas going to the indoor unit for heating.
    Get them to buy a cople of splits, it will work out cheaper in the long run just think of the power these old units consume even before you start taking into account repair costs
    Raymond
    P.S. What part of Scotland are you from.
    Sep 2003
    ISRAEL
    72
    4,248
    hi frank,
    every switch that have two wires is a contact switch, HP,LP .
    the HP is usualy has a manual reset but the LP dont, try to "bridge " it ( hope its the right term) so you will know if its that switch.
    if works, dont waste time and and leave it bgidged.
    chemi
    Oct 2001
    Nottingham UK
    5,668
    Nottingham
  1. Lennox fan coil unit question
    By THERMOACC in forum Fundamentals
    Last Post: 17-02-2006, 10:31 PM
