Thread: Reverse cycle condensing unit
03-12-2008, 01:59 PM #1
Hi all
New here so bear with me. Does anyone know what the minium air on coil is for a dx coil in a AHU when operating in the heating/reverse cycle mode in winter (eg. in winter can we use full fresh air at -4 deg c on to the coil). I heard that it was around +10 deg c minimum. We are looking to use a full fresh air AHU with the addition of a seperate heat pump condensing unit.
03-12-2008, 07:48 PM #2
Re: Reverse cycle condensing unit
It depends on what conditions the equipment was designed for.
With hot water heating coils you would expect, if I remember correctly, the pre-heat coil to lift the air temperature up to around 8 or 10°C.
Sorry, forgot my manners - welcome to the forum.Brian - Newton Abbot, Devon, UK
03-12-2008, 11:00 PM #3
If you are using 100% fresh air you need to put in a preheater if you are using a crossflow heatexchanger to recover heat from the extract and a post coil heater to boost the air temperature in very low ambients especially if there isn't much roomload.
The coils will need careful design as they will be subject to wider load variation than a standard split with low temp air on the condenser coil causing overcondensing in winter and high temperature in heating causing high evaporating temp.
Brit
04-12-2008, 03:04 PM #4
Thanks for your replies - much appreciated
condensing unit selection?
By ibraheem in forum Technical SpeculationsReplies: 0Last Post: 28-05-2008, 06:06 PM -
Thermo King OptiSet
By REEFER-TEK in forum TransportReplies: 4Last Post: 06-12-2007, 07:23 PM -
TK basic micro-p features and functions
By REEFER-TEK in forum TransportReplies: 0Last Post: 05-12-2007, 06:25 PM -
TXV sizing with a larger condensing unit
By kengineering in forum Technical DiscussionsReplies: 13Last Post: 27-08-2007, 10:44 PM
