Results 1 to 8 of 8
Thread: Climate Master Controller
03-12-2008, 01:26 PM #1
Hi, can anyone help with this one?.....I am looking for a replacement A/C Controller. The one i have just now is marked as a Climate Master......there is a part number on the back which is P/N:ETBO1BACVCCABND V3.0/OCT98 Made in Israel.
There are 12 electrical connections on the back which are in this order.
1=Low
2=Med
3=G
4=Y1
5=W1
6=R
7=X Fail
8=+N
9=-N COMM.
10=SHI
11=C 24 GND (RET)
12=R 24 VOLTS
It is also marked ET Thermostat.
I have had no luck on this item, so perhaps someone out there has worked on this controller before?
03-12-2008, 07:51 PM #2
Re: Climate Master Controller
Can't help with your model but the G, Y1, W1 and R terminals seem to be similar to Carrier connectors which are used by a few makers. Might be worth having a look at them.
11-12-2008, 09:56 PM #3
I may have possibly worked on those units in the past! If I remember correctly, any spare parts required(electrical components) were ordered from the states. I'll have a look through the filing cabinet and see if I can come up with anything
regards
Jase
12-12-2008, 02:21 PM #4
Cheers Jase.....NOV!
12-12-2008, 02:26 PM #5
could something like this be used?
http://www.buildingtechnologies.usa....anguagecode=enPaul
"KEEP IT COOL"
12-05-2010, 08:14 PM #6
I have found a controller that suits these units if its still of any use to anyone.
Its a "Rheem (mhp)" and has a biult in timeclock.
13-05-2010, 08:46 AM #7
13-05-2010, 04:22 PM #8
They are called rheem air conditioners and heat pumps for the uk
01743 463188
These controllers are a direct swap like for like, and seem to be much better.
Carrier Transicold Container Problem
By Shamel in forum TransportReplies: 39Last Post: 23-01-2012, 11:23 PM -
Daikin controller
By mchild in forum Air ConditioningReplies: 8Last Post: 02-10-2009, 07:14 PM -
Daikin Controller
By mchild in forum Air ConditioningReplies: 11Last Post: 24-11-2008, 02:34 AM -
Carell MPX master controller
By Andy W in forum CommercialReplies: 3Last Post: 30-09-2005, 07:22 AM -
Fan Controller
By Abe in forum Trouble ShootingReplies: 4Last Post: 12-01-2002, 02:21 AM
