Thread: sizing pipes
Threaded View
13-12-2008, 11:03 AM #8
Re: sizing pipes
Originally Posted by SURESH YADAV
In halocarbon (and other) people typically size pipes by velocity, which you have to do to for oil return to the compressor. At whatever velocity they use, the pressure loss will be equal to some value. Then you have to allow for the pressure loss to ensure the compressor capacity is not affected.
The higher the velocity, the greater the pressure loss will be. This contributes to excessive capacity loss for the compressor, an increase in power use, and can allow water hammer to occur in gas lines where liquid may be present.If all else fails, ask for help.
A/C Chiller Sizing tables
By romaurie in forum Tools and CalculatorsReplies: 1Last Post: 12-12-2010, 01:04 PM -
Capillary tube sizing
By Sledge in forum RefrigerantsReplies: 7Last Post: 16-11-2010, 11:44 PM -
Piping and line sizing in lbs/min
By Kathleen in forum Tools and CalculatorsReplies: 18Last Post: 29-05-2009, 03:07 PM -
Installing pipes
By tuneee in forum FundamentalsReplies: 8Last Post: 05-06-2007, 08:21 PM -
Sizing for Australia
By dogma in forum FundamentalsReplies: 5Last Post: 17-03-2006, 10:05 AM
